Home > My Range Rover > just completed my 2010 conversion
nice job Thumbs Up get rid of the exhaust Wink All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #174414 25th Feb 2013 10:46am
klf400
in all it took me about 9 months to collect all the parts , the 2010-12 parts are not that easy to get hold of s/h even though i have good access to s/h parts they dont come up that often , the bumper i bought came from a 2012 car complete with fog light bezels, towing eye cover,number plate holder,etc as these would all have been extras.
washer jets , pipe work , wing brackets , top mounting bar and fog lights were all new.
parking sensors ,headlight plugs were s/h but not easy to find .also no painting was req as the bumper and grill came to me in black , also i modded the air filter and intake pipe which is not easy but can be done, also no labour charges as i did it myself.
if it was a straight unbolt of bolt back on it would be easy but there is a lot of hidden work so i hope thish has shed light on the 2010 conversion and hope it helps others planing the same , i guess if i had bought all new parts would have been around 3k Thumbs Up 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #174530 25th Feb 2013 6:46pm
Stryke
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Is it the correct black? 2010+ black is different to pre.
I've seen complete part kits for about 2700inc vat including painted bumper! So you're about right there.
Post #174597 26th Feb 2013 1:01am
klf400
Well my colour is java black the bumper is santorini black and you can't really notice it unless you are up very close with the light in the right place as the santorini has some slight sparkle to it
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #174599 26th Feb 2013 2:19am
Stryke
Guess you're right, in the sunlight may be more visible though.
Post #174600 26th Feb 2013 2:41am
vnitos
South Africa 2016 Range Rover SVAutobiography 5.0 SC V8 Baltic Blue
@klf400 - please give more details as to how you modified the air filter box - the previous owner of my car had the 2007 modification done, but the air filter is open, which results in a bit of induction noise inside the cabin of the car.
Post #174607 26th Feb 2013 6:21am
klf400
Try this
http://www.fullfatrr.com/forum/post166605.html#166605. Thumbs Up 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #174609 26th Feb 2013 8:03am
GraemeJudge
2004 Range Rover Vogue Td6 Java Black
[quote="klf400"]Yeh it doesn't look like much but it is a lot of work , it's all the hidden stuff you can't see that takes the time , I did take some photos during the conversion but maybe not enough for a step by step
do you still have the photos of the bits you did I know it's a few years old now
Post #545899 3rd Mar 2020 6:58pm
There is a full write up in the wiki by Matt Stevenson sir Thumbs Up
Post #545901 3rd Mar 2020 7:06pm
GraemeJudge
Yes thanks but all the pictures are not showing for some reason so just wondered if someone had some pictures to go with write up
Post #545983 4th Mar 2020 4:44pm
Ashmyster79
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Re: just completed my 2010 conversion
Did you get any errors on the dash? I have the upgraded 2010 front lights and in the right hand corner I have the flashing orange light. Any ideas how to remove this?
Looks good I need to do the rear. Were they quite an easy upgrade once the clips were grinded off?
Post #573194 17th Nov 2020 2:26pm
