![]() | Home > Technical (L322) > Locking nut removal / swearathon! |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 870 ![]() ![]() ![]() |
Went to take my wheels off the other day, only to find that one of the locking wheel nuts was goosed and had been 'gunned' on.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
been there and done it..used to run a tyre center and this was a common problem, the easiest method to remove lock nuts was the 'anti clockwise socket' that you placed over the offending locknut..
It's not supposed to spin Stan! It's probably a sercurity feature to stop you just banging a socket on. It's designed so that your locking nut has to be holding both parts of it to work. Too much pressure on just the outer section and the grip on it fails and gives you a nightmare job!
tbh i havnt really looked at mine properly..it could be you're correct. |
These are the exact same nuts that I've had on all my previous FFRR's but didn't notice until this one failed, that they were in two parts.
It's not pretty....... But I was taking it off to replace it with different ones, so not the end of the world. My Previous RR's!
ohh, that bad then.. |
