Home > Maintenance & Mods (L322) > still in limp mode
v3mmtrangerover
United Kingdom 2008 Range Rover Vogue SE TDV8 Mariana Black
still in limp mode
hi all the RR is still dropping in to limp mode on accelerating I will drive all day long if you drive like a granny and don't accelerate remotely hard so frustrating I think ive done about everything now its only don 82k and sweet as a nut does anyone know some ware in the north east I can take it that's not going to cost a fortune thanks for all you help guys Big Cry Big Cry Big Cry
Post #546433 8th Mar 2020 12:40pm
DrRob
Team Valley LR get good reviews Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #546449 8th Mar 2020 2:04pm
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
Daft question have you a split intercooler hose the top ones split underneath and cause that problem , 4 jubilee clips and check them Thumbs Up
Post #546464 8th Mar 2020 5:34pm
Always
I had a limp mode issue with mine a while back. Took it to a specialist indy local to me (Halifax, West Yorkshire). They have a great bit of kit for testing for leaks in the turbo system - a pressurised smoke test kit. They found a tiny split underneath one of my turbo hoses that you could barely see with the naked eye. Without that kit it would've been nigh-on impossible to find without randomly replacing loads of bits.
That may not be your issue, but they sorted me straight away.
Sometimes a proper specialist LR garage (indy included) can be well worth it IMHO.
Edit - Probably should've named them - Stonelake LR in Halifax. They're not a main dealer, far better I think.
Should also probably add - on another occasion they found a tiny bit of wire with a nick in it that was causing all sorts of faults. How the heck they found it I don't know, but spot-on fix. Highly recommended, but not cheap.
Post #546534 9th Mar 2020 11:15am
