Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
AlanS Member Since: 23 May 2019 Location: North Lincolnshire Posts: 18 |
Mine kept smoking for a few trips. The oil collects in the V of the block and slowly trickles down. Just wait a couple of weeks and it will be gone. I went round a really sharp bend and got traction control kicking in, then 10 mins later smoke pouring out!! I thought a seal had failed but it was just more oil coming out of the V. It's not easy access to use degreaser. Time will do it better. 2012 L322 4.4 TDV8
21st Feb 2020 7:04pm |
mattgage Member Since: 21 Apr 2014 Location: Suffolk Posts: 38 |
Many thanks to mm289 and others for vital info that enabled me to (almost) sort out my oil cooler / O ring leak. Brilliant.
8th Mar 2020 5:42pm |
At least it's not an oil leak!! I was suspicious of that connector when I did mine. Seamed to connect too easily and I couldn't feel any O ring or something slide over the male part. Seemed to form a seal tho! 2012 L322 4.4 TDV8
9th Mar 2020 8:16am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1113 |
Years ago I bought a selection box of O rings off ebay and have used them numerous times on various cars for such occasions. Might be worth a try. |
9th Mar 2020 9:16am |
Thanks Alan and Kevin. Yes it clicked on perfectly - I guess as little resistance. It was dripping out quite fast once engine running. I've a feeling it's the top of the three-way EGR cooling pipe?? Anyone changed one? |
9th Mar 2020 9:54am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2308 |
The T-piece with its 3 hoses is LR022718. I'd be looking for a suitable o-ring. |
9th Mar 2020 11:30am |
Many thanks for the confirmation Graeme. Have ordered both... |
9th Mar 2020 12:24pm |
WdeRave Member Since: 25 Apr 2019 Location: Javea, Alicante Posts: 17 |
Found this surprise .....
9th Mar 2020 5:27pm |
Well done on the repair. Very strange having the bolts shear, especially when there's a rubber gasket below. 2012 L322 4.4 TDV8
9th Mar 2020 5:38pm |
That was our "thinking" as well ....
9th Mar 2020 5:59pm |
Pretty sure I have now sorted the oil cooler leak - many thanks to wisdom imparted on here which made it possible.
14th Mar 2020 12:54pm |
That o-ring is cooked like the cooler gaskets and the o-rings on the turbo oil feed pipe, so I'd keep the Viton ones with spare oil feed pipe o-rings where they'll be found when next needed. Thanks for the sizing - I'll procure a couple for when mine fails. |
14th Mar 2020 9:00pm |
Webbie Member Since: 02 Apr 2016 Location: Corby Posts: 137 |
A bit of advice and guidance please:
20th Mar 2020 1:11pm |
There's 2 types of oil leak from the cooler. 1 from the O rings as you mentioned, then also a gasket (2 gaskets) failure on the cooler itself. If you go to the top of this topic and follow the comments you will be able to find where to look to see if it's the O ring at the back. If it's O rings, it's a 20 minute job. 2012 L322 4.4 TDV8
20th Mar 2020 1:20pm |
