![]() | Home > Technical (L322) > TDV8 4.4. rpm occasionally drops out (8th gear) |
TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 124 ![]() ![]() ![]() |
Could be this
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875 ![]() ![]() ![]() |
I put up with what I described as a cough at 75-80 mph, but the dealer did the mentioned TSB software update a few years ago and it completely cured it. Been fine ever since.
roel2018 Member Since: 01 Oct 2018 Location: Groningen Posts: 42 ![]() ![]() ![]() |
Thanks for that. I will go to the local LR shop to check if LTB00454v2 is updated in my one. When was the technical bulletin published? Update: 11-May-2012
Today I was at the local LR workshop. My RR was not updated with LTB00454v2 so they runa diagnostic test. No failure was recognizable/logged, no failures for the crankshaft position sensor so that saves me a little €500 (446 pounds). The update cost me € 64 (57 pounds) so hopefully my problem is solved...
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Keep us posted |
Ok. Last year my fattie was updated with LTB00454v2 but yesterday it happens again twice! So, i think i need a new CPS Crank Positioning Sensor.... 2017 Range Rover 4.4 SDV8 Autobiography DPF EURO6- 100k miles - Dutch |
