Home > Technical (L322) > TDV8 4.4. rpm occasionally drops out (8th gear) |
TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 120 |
Could be this
12th Mar 2020 10:15am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3672 |
I put up with what I described as a cough at 75-80 mph, but the dealer did the mentioned TSB software update a few years ago and it completely cured it. Been fine ever since.
12th Mar 2020 10:30am |
roel2018 Member Since: 01 Oct 2018 Location: Aalter Posts: 34 |
Thanks for that. I will go to the local LR shop to check if LTB00454v2 is updated in my one. When was the technical bulletin published? Update: 11-May-2012
12th Mar 2020 10:40am |
Today I was at the local LR workshop. My RR was not updated with LTB00454v2 so they runa diagnostic test. No failure was recognizable/logged, no failures for the crankshaft position sensor so that saves me a little €500 (446 pounds). The update cost me € 64 (57 pounds) so hopefully my problem is solved...
19th May 2020 9:39pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4218 |
Keep us posted 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
19th May 2020 9:44pm |
Ok. Last year my fattie was updated with LTB00454v2 but yesterday it happens again twice! So, i think i need a new CPS Crank Positioning Sensor.... |
21st Jun 2021 11:05am |
