Home > Technical (L322) > Do I need the tracking checking? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4248 |
If it were me, yes Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
20th Mar 2020 10:33pm |
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 369 |
Most tyre dealers will check your tracking for free, only charging to adjust, so yes get it checked. Just make sure you use one with a computerised tracker. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
21st Mar 2020 8:00am |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 719 |
Cheers guys, will have a ring around this morning.
21st Mar 2020 8:04am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34940 |
make sure its a hunter type.... ... - .- -.
21st Mar 2020 8:30am |
Bradders Member Since: 03 Dec 2018 Location: Gods own country Posts: 417 |
^^^ what Stan said
21st Mar 2020 9:49am |
Cheers guys, had it checked and the tracking is out on the passenger side as expected
21st Mar 2020 3:54pm |
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 249 |
A 'walk' to Specsavers could also be appropriate. L322 3.6 TDV8 Vogue. 07MY ML 320 7 Seat full leather etc. (The Black Pearl) |
21st Mar 2020 8:54pm |
Although it is common practice you should not heat track rod ends to adjust them, or any other suspension components. If a MOT inspector sees evidence of heat he should fail it, obviously if you are heating it in order to remove and replace it that is okay. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
22nd Mar 2020 7:35am |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 |
Of course, no-one else apart from the OP had had an altercation with a kerb............... 2003 Range Rover Vogue TD6 |
22nd Mar 2020 11:19am |
Yeah, the mrs should of run over the poor defenseless fox 2 weekends ago. Cheers for your input |
22nd Mar 2020 12:52pm |
22nd Mar 2020 12:53pm |
Cheers all, think for the price I'm going to get both the inners and the outers and do both sides together, will i need anytihng else other than the actual inner and outer for each side? New nuts, or gaiters? |
22nd Mar 2020 12:54pm |
Inners normally come with nut but the outers sometimes come without so just check when you order. Fairly easy job really, would be worth setting up tracking with a piece of string so that it is in the right ball park for when you drive to the garage to do it properly 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
22nd Mar 2020 5:34pm |
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 284 |
I’ve read on the disco3 site & RRS that Kwik Fit (for all the negativity) do a good job if they have the Hunter system. Cost wise there is an offer where you can have it done unlimited times for a flat fee over 2 years(?). visiting from www.rrsport.co.uk |
23rd Mar 2020 2:25pm |
