Home > Technical (L322) > Do I need the tracking checking?
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Hit a kerb 2 weeks ago in the TD6 and ruined the front passenger side alloy and burst rear passenger side tyre. New set of alloys on, gave her a test drive today for a few miles and it seems ok. Should I get the tracking checked, just to be sure? Or is a good test drive enough?
Post #547781 20th Mar 2020 10:28pm
DrRob
If it were me, yes Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #547782 20th Mar 2020 10:33pm
drakes
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
Most tyre dealers will check your tracking for free, only charging to adjust, so yes get it checked. Just make sure you use one with a computerised tracker. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
2005 4.4V8 (M62) Bonatti Grey/ Parchment interior - gone
1998 4.6HSE Blue/ Cream interior (can't remember exact colours) - gone
1977 White - gone (should have kept)
Post #547798 21st Mar 2020 8:00am
mrblonde
Cheers guys, will have a ring around this morning.
Do i just ask them if they use a computerised tracker?
Post #547799 21st Mar 2020 8:04am
make sure its a hunter type.... ... - .- -.
Post #547800 21st Mar 2020 8:30am
Bradders
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
^^^ what Stan said Thumbs Up
And preferably a place used to LRs too. Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #547806 21st Mar 2020 9:49am
mrblonde
Cheers guys, had it checked and the tracking is out on the passenger side as expected
The guy couldn’t loosen the track rod end/tie rod end (are they the same thing?) even with heat, so said to get oxyacetylene on it to loosen it, am assuming any garage will do this? Then to change both track rod ends
Are these the kiddies I need to order?
https://www.island-4x4.co.uk/track-l322-de...39045.html
And should I get anything else while it’s up in the air?
Cheers
Post #547834 21st Mar 2020 3:54pm
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
Re: Do I need the tracking checking?
mrblonde wrote:
Hit a kerb 2 weeks ago in the TD6 and ruined the front passenger side alloy and burst rear passenger side tyre.New set of alloys on, gave her a test drive today for a few miles and it seems ok. Should I get the tracking checked, just to be sure? Or is a good test drive enough?
A 'walk' to Specsavers could also be appropriate. Idea L322 3.6 TDV8 Vogue. 07MY
ML 320 7 Seat full leather etc. (The Black Pearl) Wink
Post #547867 21st Mar 2020 8:54pm
drakes
Although it is common practice you should not heat track rod ends to adjust them, or any other suspension components. If a MOT inspector sees evidence of heat he should fail it, obviously if you are heating it in order to remove and replace it that is okay. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
Post #547884 22nd Mar 2020 7:35am
Brian Considine
Of course, no-one else apart from the OP had had an altercation with a kerb............... 2003 Range Rover Vogue TD6
Post #547904 22nd Mar 2020 11:19am
mrblonde
Yeah, the mrs should of run over the poor defenseless fox 2 weekends ago. Cheers for your input
Post #547909 22nd Mar 2020 12:52pm
mrblonde
Post #547910 22nd Mar 2020 12:53pm
mrblonde
Cheers all, think for the price I'm going to get both the inners and the outers and do both sides together, will i need anytihng else other than the actual inner and outer for each side? New nuts, or gaiters?
Post #547911 22nd Mar 2020 12:54pm
drakes
Inners normally come with nut but the outers sometimes come without so just check when you order. Fairly easy job really, would be worth setting up tracking with a piece of string so that it is in the right ball park for when you drive to the garage to do it properly 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
Post #547939 22nd Mar 2020 5:34pm
gettingold
I’ve read on the disco3 site & RRS that Kwik Fit (for all the negativity) do a good job if they have the Hunter system. Cost wise there is an offer where you can have it done unlimited times for a flat fee over 2 years(?). Hunt for a L405 is on.
Post #548031 23rd Mar 2020 2:25pm
