Home > Maintenance & Mods (L322) > Side steps/running boards |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 662 |
I've looked through the archives regarding side steps/running boards & found the first two links that members have used and/or recommended. The last link is from a company in Colchester that a friend bought a pair for his L405 but as you can see, L322 are out of stock. I'm in no rush, but I would like a good pair that snugly fit into the front mudflap [perhaps they all do?]. The sidesteps.co.uk although double the price, do look really good.
21st Mar 2020 5:06pm |
I fancy mudflaps [front at least] & think I need a kit rather than sidesteps from Turborevs & mudflap from Joe Bloggs.
22nd Mar 2020 1:00pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1132 |
Why don`t you fit some deployable steps and front flaps that do not have to fit the sidesteps, mounting the steps is the same work just a little bit of wiring to sort out? |
22nd Mar 2020 1:08pm |
Not a fan of deployable's to be honest. I did think along those lines but always a tad worried with operation, wiring, possible problems and most of all, cost.
22nd Mar 2020 1:14pm |
Cost is not as much as you think about £300 I have had mine for 3 years as long as they are kept clean and maintained like the rest of the FullFat no problems.
22nd Mar 2020 1:20pm |
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 179 |
Aluminium Side Steps for Range Rover Vogue L322 2002 to 2012 models Side steps provide easy access to your range rover vogue, ideal for families as access to your range rover vogue l322 is made easier and more comfortably and also provide additional styling. Manufactured from durable Aluminium and Plastic Designed to fit the Range Rover Vogue 2002-2012 models Sold as a pair Sill, Mud Guards and Brackets included Similar to OEM design at Fraction of the cost Professional Installation recommended We can also offer a fitting service contact us for a quote They come with front mud guards |
22nd Mar 2020 3:15pm |
darrenm: So they do! If I were buying purely on the look of the advert I'd have gone elsewhere as the advert shows no mudflap.
23rd Mar 2020 9:17am |
I have been very happy with mine |
28th Mar 2020 4:44pm |
