![]() | Home > Maintenance & Mods (L322) > Leave off EPB for storing? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
As I won't be using the RR for a while (now working from home) is it worth leaving the EPB "off" whilst it's laid up to stop it seizing to the rear discs? I've read somewhere it can be put in "off" by taking out a fuse???
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35719 ![]() ![]() |
just leave it in 'park'....dont activate the brake. ... - .- -.
Thanks Stan. For some reason I thought it came on automatically but that's good to know!
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
Yep. What Stan said.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3835 ![]() ![]() ![]() |
Rob/ Stan,
Page 94 in the drivers handbook tells you how to prevent automatic operation.
Ditto, but I might just take it out for a run tomorrow while we are still allowed out.
Bradders Member Since: 03 Dec 2018 Location: Gods own country Posts: 417 ![]() ![]() ![]() |
And you and yours too Mike. Current: FF Westminster money pit
interesting Mike..
Perhaps I am reading it wrong, but , my interpretation is that when you select Park and switch off ignition it automatically applies the EPB, but as the car powers down, the EPB module depowers to prevent battery drain .
so when you start and select drive/reverse you have to release the epb?? ... - .- -.
No, you don’t need to touch the brake handle.
I'll try it later again but I just put into P and then switched off without applying EPB. Locked car.
Just opened it. No red light.
