Home > Technical (L405) > Generally quiet but. |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 860 |
the ARC block is just on the front right? meaning only 1 unit? Am i seeing that its over $1000? 2014 FF Autobiography 5.0 SC
16th Mar 2020 7:20pm |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 442 |
Just for info, I have the same issue as you, if you can call it an issue. I came from a 2009 TDV8 none adaptive dynamics version to the 2015 SDV8 A/B. The old one was definitely a softer ride and rode the potholes better, but the A/B is a world away when you chuck it round bends, it stays flat with very little role, overall drives much better, but does thump over the pot holes which appear to be getting worse in the Manchester area. Interesting to see some comments about tyres and also tram-lining, I have 21' scorpion verdes on and thinking of something different when they're due a change next year as mine tends to tramline too. |
17th Mar 2020 4:48pm |
That seems to be what I’m experiencing.
18th Mar 2020 7:56pm |
Have ordered some bits, ARB bushes and Drop links. See how that goes.....
21st Mar 2020 10:03am |
Drop links done. It’s a bit better, waiting for the bolts for to do the ARB bushes.
24th Mar 2020 7:44pm |
Seems like you are just throwing parts at it? Replacing good parts for new? :Shrug:
24th Mar 2020 8:55pm |
The ARB drop links had definitely seem better days.
24th Mar 2020 9:01pm |
So tonight’s swearing was changing the ARB bushes.
25th Mar 2020 8:31pm |
Can you post images or part numbers for the part you’re swapping. For those that are following a long. I might take a look at these bits when I take my 21s off to put my summer 22s on in the next couple days 2014 FF Autobiography 5.0 SC
25th Mar 2020 8:48pm |
The bushes are LR035489, the droplinks are LR048451 and come with nuts.
25th Mar 2020 9:39pm |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 663 |
I have been chasing down a bit of a thunk/knock that ours has on the front end, everything looked great and previously reporting it to the main dealer resulting in no fault found.
21st Dec 2021 11:25pm |
Just to confirm it’s been silent since Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
29th Jan 2022 10:55am |
