Home > Technical (L322) > Hand-break doesn’t work properly
RangerKeks
Germany 2003 Range Rover Westminster Td6 Zambezi Silver
Hello to all, I’m new here. I have a problem with my Range Rover L322 TD6 2003 hand-break.
Is there someone here how nose how to make it working properly. I changed the disc and all pads and shoes also hand-break cables but it’s still not breaking well. When I go for the MOD then it’s not passed now. Maybe someone can tell me what to do more.
Thanks 🙏
Post #548356 26th Mar 2020 7:43pm
Sounds like an adjustment issue for your handbrake.
Have you gone through the adjustment procedure and turned the adjuster inside the disc until the brake disc cannot be moved, then turn the adjuster back only until you can just move the disc ?
Have your removed all the slack from the handbrake cable with the adjusters by the handle ? .
Post #548357 26th Mar 2020 8:16pm
RangerKeks
Joe90, thanks for your message. But yes I have done that. But it’s not working as it should be. When I pull the hand-break I can drive forward and backwards, and when I do that while I’m drive than it doesn’t break well 😢😏
Post #548358 26th Mar 2020 8:28pm
Do the rear discs go solid when you apply the handbrake (rear wheels off the ground) ?
If not, adjustment not right somewhere.... .
Post #548361 26th Mar 2020 9:09pm
RangerKeks
Yes, solid like a rock 😤 so what I can with my 💪🏼
Post #548363 26th Mar 2020 9:20pm
Fox889
I had a 55 plate X5 that had new discs & pads & never did have a good handbrake, just one of those things on an X5 I thought.
Doesn't help you, sorry. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #548371 27th Mar 2020 12:36am
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
RangerKeks you have PM
Made it on PM so I could explain him in German.
Post #548376 27th Mar 2020 7:44am
When you replaced thr rear discs did you check that there was no grease protection on the braking surfaces to prevent corrosion until the disks were fitted to the car. Quite often you have to degrease discs before fitting.
Post #548377 27th Mar 2020 8:29am
RangerKeks
Yes, with break clean and sandpaper. That’s not the thing, when I do this thing’s then 👍🏼 and not 👎 or 🤷🏼‍♂️. But thanks for mentioning 👌🏼.
Post #548381 27th Mar 2020 9:35am
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
I have the same problem buddy.
I will be changing out the shoes for new ones, cleaning up the inside of the brake disc and crossing my fingers......
Jim
Post #548384 27th Mar 2020 9:56am
