Home > Technical (L322) > Hand-break doesn’t work properly |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6397 |
Sounds like an adjustment issue for your handbrake.
26th Mar 2020 7:16pm |
RangerKeks Member Since: 26 Mar 2020 Location: 46395 Posts: 4 |
Joe90, thanks for your message. But yes I have done that. But it’s not working as it should be. When I pull the hand-break I can drive forward and backwards, and when I do that while I’m drive than it doesn’t break well 😢😏 |
26th Mar 2020 7:28pm |
Do the rear discs go solid when you apply the handbrake (rear wheels off the ground) ?
26th Mar 2020 8:09pm |
Yes, solid like a rock 😤 so what I can with my 💪🏼 |
26th Mar 2020 8:20pm |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 656 |
I had a 55 plate X5 that had new discs & pads & never did have a good handbrake, just one of those things on an X5 I thought.
26th Mar 2020 11:36pm |
Ansi Member Since: 07 Nov 2014 Location: Muenchwilen TG Posts: 132 |
RangerKeks you have PM
27th Mar 2020 6:44am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3951 |
When you replaced thr rear discs did you check that there was no grease protection on the braking surfaces to prevent corrosion until the disks were fitted to the car. Quite often you have to degrease discs before fitting. |
27th Mar 2020 7:29am |
Yes, with break clean and sandpaper. That’s not the thing, when I do this thing’s then 👍🏼 and not 👎 or 🤷🏼♂️. But thanks for mentioning 👌🏼. |
27th Mar 2020 8:35am |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 843 |
I have the same problem buddy.
27th Mar 2020 8:56am |
