Home > Maintenance & Mods (L405) > Battery Conditioner |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 771 |
I think you’ll find that the 12v sockets are only active when the ignition is on, so you can’t use them for battery charging.
28th Mar 2020 12:59pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1341 |
If you have tow electrics you can buy an adaptor through this site's Shop which plugs into the tow electrics socket. There are different versions depending on which charger you want to use. I've just ordered one.
28th Mar 2020 2:04pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34927 |
you could do this,
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 953 |
Sort of hi jacking this thread. My car hasn’t moved for two weeks nor will it for the foreseeable. My worry is that the battery will drain and when things get back to normal I won’t be able to start the car. I don’t have off street parking, so I can’t plug in a trickle charger - not that I have one. I’d really appreciate any suggestions or products I could source from the internet.
28th Mar 2020 3:59pm |
roberlar Member Since: 16 Feb 2019 Location: Buckinghamshire Posts: 203 |
I'd start it and stay in the car once in a while. Even ten minutes should do the trick. It's not as though there's much vehicle pollution right now |
28th Mar 2020 4:18pm |
Andy, I described a solar solution above that will work anywhere. I’ve used it for a month last summer while mine was parked at the airport and my RR started fine. MY23 D350 HSE
28th Mar 2020 4:21pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16175 |
A large solar panel on the back shelf |
28th Mar 2020 4:22pm |
Works better in the front if you have blacked out rear glass. MY23 D350 HSE
28th Mar 2020 4:28pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7764 |
I've just ordered myself another CTEK - I left mine in France |
28th Mar 2020 5:58pm |
Ocean53 Member Since: 14 Feb 2018 Location: Chichester Posts: 71 |
To plug in where? |
28th Mar 2020 6:41pm |
TomV8 Member Since: 25 Sep 2017 Location: Yorkshire Posts: 107 |
28th Mar 2020 6:52pm |
The charger comes with croc clips & a hard wire option.
28th Mar 2020 7:04pm |
Thanks
28th Mar 2020 7:17pm |
Thanks for the suggestions, but please bear with me here. I am not technically minded at all and having looked at various solar chargers on the web, it seems that you need to attach the cables to the battery terminals. That makes sense, but surely that means I have to leave the bonnet loose and the engine bay accessible to any scrote that walks past the car, which is parked on the street. In addition, wouldn’t the cable need to run through the door, so when the door is closed the cable would be pinched and have reduced functionality?
