Home > Maintenance & Mods (L405) > locking wheel nut
Blackbird
United Kingdom 2015 Range Rover Autobiography TDV6 Santorini Black
locking wheel nut
Hi Guys, does anyone know if the locking wheel nut is located somewhere in the car please. Can’t find mine. Thx Rolling Eyes
Post #548532 28th Mar 2020 12:05pm
in the boot under the load cover...on the left under a flap... ... - .- -.
Post #548535 28th Mar 2020 12:21pm
Blackbird
Stan you are a superstar. Thank you very much Thumbs Up
Post #548545 28th Mar 2020 1:38pm
i'll only be a superstar if its actually there and you find it Mr. Green ... - .- -.
Post #548549 28th Mar 2020 2:06pm
Took me a while!!
I knew it was in there somewhere...... you can only see the head of the nut! There is nothing that can't be fixed with a hammer😜😜
Post #548550 28th Mar 2020 3:02pm
Blackbird
It was there Stan but by hell the wheels are heavy to lift back on.
Post #548562 28th Mar 2020 5:04pm
thats a result. and yes they are heavy Thumbs Up ... - .- -.
Post #548563 28th Mar 2020 5:07pm
Rob99
You need a set of wheel fitting guides. See here......
https://www.fullfatrr.com/forum/topic43537.html 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #548573 28th Mar 2020 5:52pm
Blackbird
Thanks Rob I will get some guides, they must be a lot easier than trying to lift on. Thumbs Up
Post #548640 29th Mar 2020 9:50am
there is an easier way to lift the wheel onto the studs...
place wheel near the hub, hold top with left hand,place left foot on bottom left and then use a lever on the bottom right to wiggle the wheel on...
its harder to explain than its actually to do... ... - .- -.
Post #548642 29th Mar 2020 9:56am
Blackbird
Thanks Stan, it sounds like I need practice to get the technique right.
Post #548660 29th Mar 2020 12:14pm
GGDR
Me: Don't jack it more than needed, line up the studs then a foot under each side.
Bottom first; use feet to lift and locate and hands just to steady and guide.
. Cheers, Greg
Post #548666 29th Mar 2020 12:42pm
Blackbird
Thanks Greg will try. I have a trolley jack but only used the one provided with car yesterday. If using a trolley jack where is the best place the jack on the RR. Jim.
Post #548679 29th Mar 2020 2:06pm
