Home > Maintenance & Mods (L405) > locking wheel nut |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34915 |
in the boot under the load cover...on the left under a flap... ... - .- -.
28th Mar 2020 12:21pm |
Blackbird Member Since: 22 Feb 2020 Location: York Posts: 26 |
Stan you are a superstar. Thank you very much |
28th Mar 2020 1:38pm |
i'll only be a superstar if its actually there and you find it ... - .- -.
28th Mar 2020 2:06pm |
Took me a while!!
28th Mar 2020 3:02pm |
It was there Stan but by hell the wheels are heavy to lift back on. |
28th Mar 2020 5:04pm |
thats a result. and yes they are heavy ... - .- -.
28th Mar 2020 5:07pm |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1328 |
You need a set of wheel fitting guides. See here...... https://www.fullfatrr.com/forum/topic43537.html 2017 4.4 SDV8 Autobiography 2012 4.4 TDV8 Westminster - Gone, but not forgotten |
28th Mar 2020 5:52pm |
Thanks Rob I will get some guides, they must be a lot easier than trying to lift on. |
29th Mar 2020 9:50am |
there is an easier way to lift the wheel onto the studs...
29th Mar 2020 9:56am |
Thanks Stan, it sounds like I need practice to get the technique right. |
29th Mar 2020 12:14pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Me: Don't jack it more than needed, line up the studs then a foot under each side.
29th Mar 2020 12:42pm |
Thanks Greg will try. I have a trolley jack but only used the one provided with car yesterday. If using a trolley jack where is the best place the jack on the RR. Jim. |
29th Mar 2020 2:06pm |
