![]() | Home > Technical (L322) > TDV8 09 fails to crank after switching off unless hard reset |
| GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2774
I would invest in a new stop-light switch as they often fail and are cheap enough to try even though probably not the cause. |
| Marzipan Member Since: 02 Apr 2020 Location: North West Posts: 23
Thanks for the response and suggestion, it's a complicated beast so I am hoping someone on here has come across this before |
| cass Member Since: 12 Oct 2011 Location: northumberland Posts: 797
How about the the ignition switch?
It could be the switch but as that looks to be a difficult job I am trying other possibilities first. At the moment I would like to find the BCM.
| Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 701
Punching in the dark a little here, but, can you disarm the alarm/immobiliser, central locking to see if that makes a difference? Try & leave your car unlocked overnight (scary I know) then start-drive-restart the next day without unlocking the car (process of elimination)? What I'm trying to do is elimate or highlight who or what is playing silly b's? Another wild thought is a sticky relay (if that actually exists?)........as I say, punching in the dark. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
The BCU should be under the front passenger seat judging by the diagram in the parts catalogue, although I wonder what you might do in the way of checking it other than re-plugging its connectors. |
Hi Fox889, no sure how to do that and as you say scary.
Hi GraemeS,
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
I presume you do not have any diagnostic equipment? Without checking for codes your playing guessing games im afraid...
All that's happening when you do your reset is that power is cut from all the modules draining their storage capacitors within the 1st half a second or so of the first battery lead being disconnected thereby forcing a cold start of the modules when power is reconnected. Whatever is going wrong is leaving a module in a messed-up state which is cleared on a cold start.
Hi Graemes and Craig, firsly thank you for responding to my problem,
sorry GraemeS thanks for the tip about following fitting instructions with the sl switch. The car is full of sneaky traps, I have been told not to trial a used BCM as this will imprint my car with the mileage of the car it was taken from!
I do think you’d be better off with an IID tool or something of that ilk! Trying to diagnose a fatty without diagnostics is much harder, if not impossible! And if it simply wants the BCU or LCM reflashing, you cant do that without a decent tool!
You may need to use a diagnostic tool that provides live values to see what is not correct when trying to restart if no faults are stored, but hopefully 1 or more fault codes will point to a particular fault. |
