![]() | Home > Maintenance & Mods (L322) > Rear wiper - worn spline? |
The motor will be just fine as it is... Just replace the arm sir |
stuartj9 Member Since: 18 Apr 2019 Location: Liverpool Posts: 86 ![]() ![]() ![]() |
Thanks for the reply. Does the spline on the motor look OK? It looks a bit worn to me.
Yes it looks a little worn but put an arm on with decent spline's and im sure it will work fine sir |
o you also have a link to Ebay for the correct rubber seal for the motor please? It's slightly leaking inside the car. Thank you. |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 ![]() ![]() ![]() |
Here's what I'd do to find the seal.
Thanks Stu, that's a great site for parts - bookmarked! It's the wrong seal though. I need the one that connects to the motor and water pipe. This is where it's leaking from. Cheers |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
https://www.fullfatrr.com/forum/topic9792.html
Cheers. I used the link on there but looks to be gone from Ebay. There's others but I need to get the correct one. I also need the self tappers. |
All sorted. Spline cleaned with a blade, wiper arm sanded and resprayed and arm now back to the correct position Thanks to everyone that helped.
