Home > Maintenance & Mods (L322) > Rear wiper - worn spline? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
The motor will be just fine as it is... Just replace the arm sir |
4th Apr 2020 11:11pm |
stuartj9 Member Since: 18 Apr 2019 Location: Liverpool Posts: 86 |
Thanks for the reply. Does the spline on the motor look OK? It looks a bit worn to me.
4th Apr 2020 11:13pm |
Yes it looks a little worn but put an arm on with decent spline's and im sure it will work fine sir |
4th Apr 2020 11:24pm |
o you also have a link to Ebay for the correct rubber seal for the motor please? It's slightly leaking inside the car. Thank you. |
4th Apr 2020 11:41pm |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 |
Here's what I'd do to find the seal.
5th Apr 2020 12:00am |
Thanks Stu, that's a great site for parts - bookmarked! It's the wrong seal though. I need the one that connects to the motor and water pipe. This is where it's leaking from. Cheers |
5th Apr 2020 12:08am |
https://www.fullfatrr.com/forum/topic9792.html
5th Apr 2020 1:25am |
Cheers. I used the link on there but looks to be gone from Ebay. There's others but I need to get the correct one. I also need the self tappers. |
5th Apr 2020 4:36pm |
All sorted. Spline cleaned with a blade, wiper arm sanded and resprayed and arm now back to the correct position Thanks to everyone that helped.
11th Apr 2020 8:42pm |
