![]() | Home > Maintenance & Mods (L405) > oil cooler 4.4 sdv8 possible leak |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Go for the OEM You don't want to do it twice? |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Thanks Tinman , wise advice , I was hoping someone on here might know who manufactures the oil coolers for LR and that it would be Nissans. 2015 4.4 AB
Original is made by Mann + hummel for LR 2015 4.4 AB
What warranty do you get with non-LR part? Form speaking to my son who bought a new Nissan Navara their parts are not bulletproof?
Hi Tinman, the part is made by Nissens automotive , they are a automotive parts manufacturer, they warranty is 2 years as opposed to the LR oil cooler ( made by Mann ) whcih has 2 year warranty 2015 4.4 AB
Sounds like Apples for Apples, difficult choice? check the small print for returns Like fitting by a qualified person? |
Hi Tinman, sorry the LR one ( Mann) has a 1 year warranty not two. My thoughts are its proberbly just the gasket as its a very minor leak but for the cost of a non LR replacement is it easier just to change the oil cooler instead of pulling the old one apart. My indie is a great believer in OEM spec parts as long as they are from a reputable manufacturer or the same manufacturer who makes the part for LR. 2015 4.4 AB
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 ![]() ![]() ![]() |
Had mine done under warranty by the stealer in late 2019, it still looks to be leaking. Genuine land rover part is about £400 if i remember correctly. However on the L322 we did this not long ago and it was a ECP special for £85... I dont rate ECP, but its not failed so far..
Thanks Charles , mine seems to be coolant so probably not the two o rings and more likely the oil cooler. I will ask them to change the o rings while they are fitting the cooler. I'm amazed how the spurious company can manufacturer such a specialised part for such cheap money. Do they sell that many that it is worth their while ?
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3883 ![]() ![]() ![]() |
Dolph34,
Thanks Mike , would you have a part number sir ? 2015 4.4 AB
Not a part number, but here is an eBay link to the correct size Viton O rings.
Your a gent , thank you 2015 4.4 AB
