Home > Technical (L405) > Low battery warning but which battery?
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
Folks,
Been getting the low battery warning last couple of weeks. No surprise since of course the car is hardly being used. But I have had it on a trickle charger so I am actually surprised.
But my question is this. When you get this message on the dashboard, how do you know which battery is the one that’s low?
Is it the main battery (under the spare wheel) or is the accessory battery inside the rear wing?
Or.... is the error message agnostic of which battery. In other words, it just sees a combine low voltage over both and it’s down to good old detective work to work out which battery is tired and duff?
Orrrrrr. Final option. Is the battery actually charged (by the trickle charger) but the BMS doesn’t recognise it?
Thanks.
Post #549988 11th Apr 2020 2:28pm
ur20v
A Trap
Do you have a multimeter?
Post #549990 11th Apr 2020 2:41pm
Fleagle_UK
Yes
Post #549991 11th Apr 2020 2:42pm
ur20v
A Trap
Disconnect the batteries and test each one, over 12.5v and the battery should be ok, bellow, charge for 24hrs and retest after being left for an hour or so off the charger.
If the batteries are not connect to each other then you might be able to test both in place and connected?
Have you checked the car is charging properly?
Post #549994 11th Apr 2020 3:11pm
Fleagle_UK
Thanks.
My post really was more about questioning the cars system of operation rather than how to manually test batteries.
Thanks again.
Post #549995 11th Apr 2020 3:16pm
Chalky
Had the same and it was the main battery.
Turned out the Blackvue Dashcam was the problem. Turned the Parking mode off on the Dashcam even though I had a Power Magic Pro wired in which is supposed to save battery. It's a known problem Censored Whistle All LR cars from 1984
2021.5 Vogue SE D300 Carpathian Grey
2018 Vogue SE British Racing Green GONE
Post #549998 11th Apr 2020 3:25pm
it will the main battery.... ... - .- -.
Post #550000 11th Apr 2020 3:29pm
roberlar
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
I've replaced both on mine within the last few months and it still shows low battery after three or four short journeys. Turns out both of the old batteries are still good and holding charge so they've been put to other uses which is fine in my case, but not so good otherwise. A voltage test seems to be the first port of call.
Post #550066 12th Apr 2020 11:11am
did you reset the battery on yours Rob when you fitted the new one... ... - .- -.
Post #550067 12th Apr 2020 11:14am
roberlar
Yes Stan, in both instances re-set by professional mechanics. I do wonder whether the message appears on the basis of journey duration because as said, the old batteries are fine, and the new batteries should be as well.
Post #550069 12th Apr 2020 11:21am
thats my theory out the door then Laughing ... - .- -.
Post #550072 12th Apr 2020 11:36am
Re: Low battery warning but which battery?
Fleagle_UK wrote:
Folks,
Thanks.
Is it reporting a low battery even when its on a charger/charged?
Post #550076 12th Apr 2020 12:09pm
Fleagle_UK
No Craig.
but it will 24 hours later after being on charged even if the car wasn't driven. So either one of the batteries is goosed or there is quiescent drain somewhere.
The main battery is 2.5 years old. No idea how old the ancillary battery is.
Post #550111 12th Apr 2020 5:23pm
If the main batt is only that old then you wouldn’t expect it to be goosed.
What battery is it? There is nothing that can't be fixed with a hammer😜😜
Post #550118 12th Apr 2020 6:11pm
So, does it go through a charging cycle? Does it get to the end of charging and tell you it’s charged? And then tell you 24hrs later it’s low?
Post #550121 12th Apr 2020 6:19pm
