![]() | Home > Technical (L405) > Air con failed again! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35858 ![]() ![]() |
put it in manual and play about with the temperatures.... ... - .- -.
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 409 ![]() ![]() ![]() |
Mine had a very small leak in the condenser - which is where most systems fail. It was pressure tested and was fine. It was only when the system was re-charged and started to get hot that the leak showed up.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8785 ![]() ![]() ![]() |
Needs the pressures checking to see if it’s lost the gas.
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1524 ![]() ![]() ![]() |
Depends which gas it runs on, mine is about £300 for a regas |
All 405's are the same expensive gas DrF... |
nwmgc Member Since: 27 Jan 2014 Location: London Posts: 159 ![]() ![]() ![]() |
Thank you all for the sage advice. I have read that the newer refrigerant is exceptionally leaky and suspect it’s that. It is the sort of thing, though, that when it is fixed, you are always waiting/ worrying that it will fail again! Bring back full fat gas, I say. |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
A bit more on Aircon here :-
Mine went wrong last year which showed a leak in the condenser so I replaced that! Then it leaked out again and it was traced to an aluminium pipe for the rear AC! Had corroded where a steel clip fixed it in place!!! Good old JLR!!! |
Thanks for this - my search skills are poor! |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3274 ![]() ![]() ![]() |
They don't seem to learn. A steel clip for an aluminium air con pipe was a common fault with the D2. ![]() 2008 Stornoway Grey 3.6 Tdv8 Vogue - SOLD 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT-Sold |
Well, my warranty does run until October... ![]() |
So does mine but JLR extended warranty doesn't cover AC!!! |
Hopefully as I have the full Approved (rather than extended) warranty, it will be covered. Gas on its own, is not, but it may well have leaked away from some covered component! |
As there is no sign of garages opening anytime soon, I called in wechillanycar.com.
