Home > Maintenance & Mods (L322) > 2012 tdv8 4.4 shock absorbers.
sean mullane
Ireland
hi, im looking for rear shock absorbers , whats good , and what should be avoided, also where to purchase. thank you . sean
Post #550878 18th Apr 2020 10:46pm
be aware that you have a adaptive dynamics car so the new shockers will need to be compatible so the cheap ones won't work. From what I can remember there are only a few options. The LR ones are about 350 a side, the aftermarket ones about 300... There is nothing that can't be fixed with a hammer😜😜
Post #550881 18th Apr 2020 10:57pm
Have them checked and double checked as they leaked from near new! Many have damp tops but work perfectly!
Tis a lot of money to spend if they are not necessary sir Thumbs Up
Post #550889 19th Apr 2020 12:12am
As Craig says, they all weep a little bit and show a mist of oil
On my 4.4 they had a mist of oil for a few years and were still fine when I sold it. There is nothing that can't be fixed with a hammer😜😜
Post #550890 19th Apr 2020 12:15am
sean mullane
Ireland
i think it needs new ones as it rolls like a boat and it hits the bump stops with the slightest bump, on a speed hump the rear lifts really high , thank you for your replies and taking the time to reply ,, sean
Post #550892 19th Apr 2020 12:19am
Seams you are the unlucky one then sir Whistle
Try English breakers? They have an easier life over here as we have more motorways Thumbs Up
Post #550894 19th Apr 2020 12:23am
GraemeS
Australia
I replaced my rears with Bilsteins. I felt safe using Bilsteins because their firmness is ecu-controlled. I had Bilstens on a D2 and found them excessively firm but they're fine on the L322.
My fronts aren't as bad as the rears were after towing my 2.5T van on rough roads but they will be replaced when funds permit.
I recalibrated my shocks twice with my IIDTool to get more life from them then recalibrated again with the new Bilsteins so that the ecu could take into account the new performance from the rears.
Post #550901 19th Apr 2020 4:48am
Mikey
Replaced a few over the past while
Either they leak, or they have absolutely no damping at all
At the time, they were only available as a genuine LR part...
Post #550908 19th Apr 2020 7:25am
The bilstein ones are nearly as much as the LR ones. There is nothing that can't be fixed with a hammer😜😜
Post #550926 19th Apr 2020 9:09am
sean mullane
Ireland
thank you for your replies and help . i priced main dealer and was quoted nearly 1000 euro per unit. bilstein prices were about 650 euro for both , i ended up buying the shock absorbers from aerosus in germany suitable for variable dampening costing 450 euro for both..
Post #551748 26th Apr 2020 4:07pm
LRDirect had he LR ones at 350 per unit, but 450 for both seems decent, let us know how you get on with them Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #551749 26th Apr 2020 4:19pm
sean mullane
Ireland
Aerosus shock absorbers fitted. Fantastic difference to the driving of the Range Rover . Beautiful handling on all types of roads ,
Post #555853 30th May 2020 2:53am
coopss
Might get some for mine. How many miles on yours? 1995 4.6 v8, green/tan (long gone)
2005 4.8iS X5, blue/black
2011 4.4 tdv8, black/black (gone)
2003 3.0d X5, Oxford green/black/manual
2021 p575 SVR, BR green/vintage tan
Post #555892 30th May 2020 12:52pm
sean mullane
Ireland
160000 miles -200000 km
Post #556899 8th Jun 2020 11:19am
nino_nino
160 000 mi - 257 000 km 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #557045 9th Jun 2020 10:44am
