Home > In Car Electronics (L322) > What is this ?
L3223
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
Yes, did wonder if it was a dvd for sat nav
Post #551353 22nd Apr 2020 8:50am
L3223
Sorry misread reply
Yes guessing it is a micro sd card, just not sure which one
Unit seems to suggest it comes with preloaded maps but none on this one
As I use waze now, not sure I would bother anymore with outdated Range Rover map software
Post #551355 22nd Apr 2020 9:29am
Danwilderspin
If you eBay Android usb carplay there are plenty in the uk.
On mine it had usbs at the back . If they fitted properly the would have probably made the accessible from the glove box. If they didn’t you may get lucky and be able to remove the center speaker and fish the usb sockets out and plug it in. If you are really unlucky you will need to remove the dash top.
I ha e the wireless version which was a bit more but can be handy. I’d say 1/20 times it won’t connect wirelessly so I plug a lead in.
Cheers Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #551388 22nd Apr 2020 2:04pm
L3223
Just found these so maybe all sorted
Battery all disconnected so can’t test them yet
Post #551389 22nd Apr 2020 2:13pm
L3223
Post #551390 22nd Apr 2020 2:14pm
Danwilderspin
yep get one of those CarPlay boxes and plug it in to the extension and you will be happy - I only use CarPlay in mine Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #551405 22nd Apr 2020 4:08pm
L3223
Currently trying to mend a coolant leak but fingers crossed can mend it and once all electrics work can add new toy
At least wuhan makes something you actually want !!
Post #551417 22nd Apr 2020 7:43pm
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
You can download and install any Navigation App that works on Android, load the map on a Micro SD.
In my 2004 I installed a Xtrons Android 8.0 and beside of Google Maps I had also Here WeGo Nav-App and maps on the Micro SD.
Post #551420 22nd Apr 2020 8:18pm
L3223
Cheers Ansi
Another day filled in lockdown 🦇
Might test my IT skills but will persevere
Post #551432 22nd Apr 2020 9:58pm
