Home > Maintenance & Mods (L322) > Headlamp lens replacement
TonyB
I need to fit a new lens to the offside headlamp (2012 Westminster) and I understand I need to heat up the headlamp, to soften the glue to remove the old lens. Given the cost of a replacement leadlamp unit, it seems the smart thing to try to replace the lens. Any do's and dont's before I splash out?
Post #551821 27th Apr 2020 2:31pm
are new lenses available then? ... - .- -.
Post #551823 27th Apr 2020 2:39pm
TonyB
Powerful UK
https://www.powerfuluk.com/vehicles/range-...right.html
Post #551825 27th Apr 2020 2:56pm
WB
Are you replacing them because they're cloudy or for another reason? If it's exterior cloudiness it may be possible to polish your current ones rather than replace.
Post #551833 27th Apr 2020 3:25pm
TonyB
Unfortunately not, the lens is scratched. Too deep to polish out.
Post #551834 27th Apr 2020 3:29pm
Tony, you will struggle to remove them by heating them up as the glue is not the same as the early lamps and does NOT soften when heated! Ask me how i know Rolling Eyes
Just wouldn't want you ruining your headlamp case overheating it! Thumbs Up
Post #551887 27th Apr 2020 11:32pm
So I take it you grind the old one off, after several beers so your hand is steady...?? Pete
Post #551889 27th Apr 2020 11:42pm
Ive only ever removed broken ones but tried removing some in the early days of the 2009 facelift without much luck Pete!
Post #551891 27th Apr 2020 11:55pm
