|  | Home > Maintenance & Mods (L322) > Headlamp lens replacement |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35884    | are new lenses available then? ... - .- -.
|  27th Apr 2020 1:39pm |
| TonyB Member Since: 02 Oct 2017 Location: Hampshire Posts: 14      | Powerful UK
|  27th Apr 2020 1:56pm |
| WB Member Since: 26 May 2016 Location: London Posts: 304      | Are you replacing them because they're cloudy or for another reason? If it's exterior cloudiness it may be possible to polish your current ones rather than replace. | ||
|  27th Apr 2020 2:25pm |
| TonyB Member Since: 02 Oct 2017 Location: Hampshire Posts: 14      | Unfortunately not, the lens is scratched. Too deep to polish out. | ||
|  27th Apr 2020 2:29pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Tony, you will struggle to remove them by heating them up as the glue is not the same as the early lamps and does NOT soften when heated! Ask me how i know   | ||
|  27th Apr 2020 10:32pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | So I take it you grind the old one off, after several beers so your hand is steady...?? Pete
|  27th Apr 2020 10:42pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Ive only ever removed broken ones but tried removing some in the early days of the 2009 facelift without much luck Pete! | ||
|  27th Apr 2020 10:55pm |
| Posting Rules
