![]() | Home > Technical (L322) > Squeeking behind dash |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1197 ![]() ![]() ![]() |
I wonder if it could be the vent control stepper motor.
Garnerj Member Since: 07 Aug 2018 Location: Milton keynes Posts: 67 ![]() ![]() ![]() |
thanks rjff. Stepper motor, thats the term i needed I think! |
Thanks for the info from all so far, I now think Im pretty sure I know what it is.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
ooer missus !! ![]() Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
Can you get at it if you remove the dash top ? .
Shows I have not done that much reading up, I though the dash came off as one piece like my old p38 does. Will have a look at that. I have also just had the thought of perhaps being able to take the pollen filter housing out and that may give me clear access. Just gotta see how easy that is or whether loads of other stuff has to come out first! |
Removing cabin/pollen filter housing
I can confirm that I am able to get to the affected area through removing the cabin filter, thanks for the suggestions folks. A quick blast of silicone hasn’t solved the issue though so I will have a better look over the weekend.
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 200 ![]() ![]() ![]() |
Did this ever get sorted or have you worked out if it was what you first thought? I’m having a similar issue with a chirp/squeak from behind the dash so curious as to the outcome. TYIA! Andy
Bolert Member Since: 29 Jun 2021 Location: Hythe, Kent Posts: 35 ![]() ![]() ![]() |
Good morning peeps,
