Home > Technical (L405) > 2019 Matrix Light upgrade (Wiring) |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1245 |
Interesting options there |
30th Apr 2020 8:36pm |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 860 |
i dont know about that....if your view their website and instagram, FB etc they are doing extensive retrofitting as well. Their work looks pretty quality. For example they are retrofitting LED modules into Evoque lamps 2014 FF Autobiography 5.0 SC
1st May 2020 3:10am |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
@Jettec that was not my understanding, I may be wrong but I contacted them re my 2015 model and it was my model we discussed. In the email they clearly say we need your headlamps to retrofit full led. They also mention painting options. Also the 20182₩19 headl lamps dont fit my model. 2015 4.4 AB
1st May 2020 4:23am |
jettec Member Since: 16 Jul 2013 Location: Melbourne Posts: 229 |
Hi Dolf34 no if you read their information they supply the RDMatrix computer unit and program it to your new 2018 Matrix headlights.Then you have all the functions on the new Matrix lights working on you old car.
1st May 2020 8:48am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16170 |
Pic below if that helps sir...
1st May 2020 10:12am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3641 |
This is all a bit confusing - I assume that UNLESS I want to replace my 2013 headlights with later ones to get laser brightness together with all the faff of getting a new bonnet fitted, then this is a possible option - or am I missing something?
1st May 2020 11:03am |
Hi Geoff , I have emailed them this morning to get clarification, its italy so not sure if they are working today. 2015 4.4 AB
1st May 2020 11:30am |
Geoff |
1st May 2020 11:44am |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2598 |
Ah, if you look at the pic of the manual on their website it’s a retrofit adapter. Oh well lads, need to find something else to spunk cash on .. |
1st May 2020 3:01pm |
Hi All , got an answer re new headlight or not this morning from Italy and it seems they do the work on your original headlights please see below
4th May 2020 8:14am |
Well that does sound interesting!
4th May 2020 9:02am |
Jettec, it does sound much better than having to change the lights and any bodywork + alot cheaper. 2015 4.4 AB
4th May 2020 10:50am |
Can you send me the contact there you’re using? I’ve tried sending them an email through their site and also an email and got no response.
4th May 2020 11:47am |
I'm using the info@rdcustom.it email address , they seem to respond very quickly in the morning ( pre 10am) but not so quick the rest of the day. 2015 4.4 AB
4th May 2020 11:52am |
