Home > Maintenance & Mods (L322) > TDV8 3.6 Engine Mounts
Freedriver
Australia 2009 Range Rover Autobiography TDV8 Zermatt Silver
Hi there everyone. I have noticed some uneven wear on the tires ant a bit of a harsh feel over bumps so took the rangie in for a check up at a suspension “specialist “ . I’m pretty sure they thought I had no idea how a vehicle works so went ahead and reported nearly everything as failed including but not limited to; steering rack, all shocks and engine mounts . They also told me that a high pressure power steering pipe had rubbed through. I must admit I struggled to keep a straight face listening to all this . I haven’t received a quote for repairs yet but was told it would be between 10 and 15 k aud. Anyway after arriving home I decided to remove the front wheels and have a look for myself. All I found was a slight leak in the steering and a bit of wear in the control arm bushes.
The engine mounts I’m not sure about, I put a jack underneath and pushed up until it felt like I was getting resistance. I am sure however I can’t move the engine easily by hand. I also had someone engage gears while I watched the mounts and saw little to no movement.
My question for you is how do the engine mounts normally fail? I remember on the d2 they gradually collapsed and became harsh . Is it the same for these ? And is there a history of the engine mounts separating (as I was told “both on the right side are completely separated and you can lift the engine by hand”
Also , what are the vacuum lines in the engine mounts for?
Here are some photos of the mount with a jack pushing them up. Do they look normal [i
mg]
Thanks[/img]
Post #552243 1st May 2020 3:35am
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
Hi Freedriver,
Put aulro.com into your search engine.
There are plenty of members in Darwin(and elsewhere in Oz) that could give you advise re your problems.
I have the older TD6 model so cant advise either way.
Hope that helps.
cheers
littlecub
Post #552395 1st May 2020 10:13pm
kbald
I think the engine mounts are hydraulic so that's what the lines would be for. If they are firm and no movement then surely they are fine. I can't recall seeing a post on here about engine mounts failing in the 5 yrs I've been watching the forum but could have missed it. Don't think it's a common problem though. Have you tried tightening the bolts? And are you getting a lot of vibration through the car? When the mounts were shot on my 911 the passengers seat would be shaking at idle. Totally different car I know but same principle of engine not secure your get some vibration. Current 2007 TDV8 Vogue Buckingham Blue
Post #552412 2nd May 2020 7:43am
littlecub
Try these guys , just had a look on aulro for you.
European Vehicle Servicing, 1/6 Downes Rd Winellie, 08 8984 3590, 0439 771 655, Neil Simmonds is the man.
europeanvehicleservicing@hotmail.com
Post #552481 2nd May 2020 8:36pm
littlecub
Another one...
https://lrant.com.au/
Post #552484 2nd May 2020 8:46pm
Freedriver
Thanks for the replies guys. When I took my car in the description of the problem I gave the suspension guy was tires wearing on the inside and a hard fide Omer bumps in the rear . Other than that it drives beautifully. I have ordered new rear shocks and Some bushes for the rear, front control arms and will get an alignment once fitted . I am just blown away by how unprofessional the shop I took it to are. Might ask them if they checked the muffler bearings if they get back to me with a quote.
I have been to LR automotive and chatted with Leigh, he is a good bloke and always busy with a herd full of landies. That is the only place in Darwin I see them .
Post #552493 3rd May 2020 4:37am
