Home > Maintenance & Mods (L322) > Front diff and drive shaft removal TD6
JohnK
United Kingdom 2003 Range Rover HSE Td6 Zambezi Silver
Hi All,
Currently in the middle of swapping my engine, has anyone got any tips for removing the front diff and drive shaft that goes through the sump?
Rave is full of special LR tools, hoping someone has some time saving ideas?
Post #552061 29th Apr 2020 3:58pm
Apart from the engine hoist and a ball joint cracker, seems the inboard drive shaft tool and oil ring/bearing setter are the ones most likely to present an issue, But I am certain folks on here have got their driveshafts out and back without "special" tools.... .
Post #552064 29th Apr 2020 4:21pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
i would like to hear your comments as you go through this RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #552110 30th Apr 2020 1:59am
JohnK
I'll keep this thread updated, so far i'm just struggling with the ball joints!
Post #552143 30th Apr 2020 12:54pm
knares
thanks RR 2005 4.4 petrol
Post #552144 30th Apr 2020 12:58pm
I had to resort to a big one of these, and a sledge
Post #552149 30th Apr 2020 1:34pm
JohnK
Right......
Got the B*s*ard ball joints undone today, used a scissor type splitter that was done up until it looked like a banana, some heat applied then a ruddy big pair of hammers.
As for the drive shaft, once the hub was free, I undid the bearing carrier from the sump and levered between a rib on the sump and the bearing carrier and it popped out, not too much force needed.
Then a little bit more levering to get the shaft out of the bearing carrier so it could be withdrawn as the carrier wont fit through the gap where the driveshaft has to go.
No special tools needed.
Post #552321 1st May 2020 5:43pm
