![]() | Home > Technical (L322) > 2011 4.4TDV8 coolant expansion tank swap |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1197 ![]() ![]() ![]() |
I may be wrong but have a loook at the connections on top of the fuel cooler. They have one or two push in plastic pieces
ScubaVogueSE Member Since: 07 Apr 2019 Location: Kent Posts: 29 ![]() ![]() ![]() |
Great diagram!
Thanks
Thanks
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3850 ![]() ![]() ![]() |
Nino will be able to help.
Thanks!
I think it looks lke this
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Steve, take air filter box out and you will have plenty of space to work. fitting is like one in the picture posted by rjff. air box is held in place by tree rubber grommets, so just pull it out. 2012 TDV8 Black Edition
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1324 ![]() ![]() ![]() |
Hi Steve. Can I ask why you are changing it? I have a mysterious leak and wonder if you have the same problem. Thanks Kev. |
Hi Nino, thanks for the advice, glad I took the airbox out.
So, thanks for the advice, I managed a swap, quite painless, touch wood!
It will be nice to see the level of the coolant from the outside mate. Mine is as dirty as your old one and I have to take the cap off to see the level. Dare I ask how much the new tank cost? Cheers Kev. |
Kevinp, You can clean existing tank, I did. check this post - https://www.fullfatrr.com/forum/topic43284...k+cleaning
