![]() | Home > Maintenance & Mods (L322) > Does this look like water ingress? |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
Looks like water ingress to me. |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826
I concur, typical water stain, the carpet has up to 6" of foam on the back and the carpet will be dry but believe me the foam will stay wet for months, best thing to do is strip out the interior and let it dry out, you can also check all the wiring although there aren't many connectors under the carpet, most are in plain site under the seats etc...
| stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276
Great pictures |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885
pete's project pics, love 'em.. |
| Walter Skinner Member Since: 02 Oct 2019 Location: Varna Posts: 61
Thanks for your reply & great photos, now I have a plan of what to do. Stripping the interior sounds so exciting! But now I have couple other questions... - Is whole carpet a single part? Or front/rear divided? - Can I hook up battery terminals & drive (start/move) the car with front passenger seat missing, wouldn't that cause any SRS issues? I see your point about no connectors, but still want to start with examining this loom as it goes from the boot where PDC ECU is and straight to the LCM. As for the OBD port, attaching the pic below. BTW, what are 3 pins sticking from the port cover? What's their functions? I'm pretty sure I've been driving the car with the cap hanging open for quite a while...
Carpet is one piece and goes over the center console, I saved a couple of hours and just loosened the console , pulled it up and cut the carpet both sides leaving enough to go under the console when refitting, it worked well and made it much easier to remove...
Great idea about the carpet, thanks!
Never heard of that scanner but there are some out there which just won't read some ECU's... worth checking yours on another fatty or trying one known to read other fattys ok on yours before you condemn the car...... Pete
I'm pretty sure it was reading those modules when I've only purchased the car, I even have some photos of (supposedly?) LCM & PDC ECU's I made when first time hooked the scanner to the car:
Have you checked the fuses...!!
Those errors were most probably caused by the dead battery, once cleared they never popped up again... First couple months of ownership everything except Air Suspension & front blower motor was working fine... Than it started to rain & more or less at the same time "LCM" issues started |
Fuses need to be pulled to check them properly, if they have got wet then they can grow salts and can create a high resistance.. Pete
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Have you looked inside the PDC module?
Yup, with no luck unfortunately. Haven't opened the case, just unplugged the PDC module.
| All times are GMT |
