|  | Home > Maintenance & Mods (L322) > Does this look like water ingress? |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989      | Looks like water ingress to me.  | ||
|  5th May 2020 8:55am |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | I concur, typical water stain, the carpet has up to 6" of foam on the back and the carpet will be dry but believe me the foam will stay wet for months, best thing to do is strip out the interior and let it dry out, you can also check all the wiring although there aren't many connectors under the carpet, most are in plain site under the seats etc...
|  5th May 2020 9:37am |
| stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276      | Great pictures   | ||
|  5th May 2020 10:08am |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35884    | pete's project pics, love 'em..  | ||
|  5th May 2020 10:29am |
| Walter Skinner Member Since: 02 Oct 2019 Location: Varna Posts: 61      |
 Thanks for your reply & great photos, now I have a plan of what to do. Stripping the interior sounds so exciting! But now I have couple other questions...   - Is whole carpet a single part? Or front/rear divided? - Can I hook up battery terminals & drive (start/move) the car with front passenger seat missing, wouldn't that cause any SRS issues? I see your point about no connectors, but still want to start with examining this loom as it goes from the boot where PDC ECU is and straight to the LCM. As for the OBD port, attaching the pic below. BTW, what are 3 pins sticking from the port cover? What's their functions? I'm pretty sure I've been driving the car with the cap hanging open for quite a while...
|  5th May 2020 3:18pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | Carpet is one piece and goes over the center console, I saved a couple of hours and just loosened the console , pulled it up and cut the carpet both sides leaving enough to go under the console when refitting, it worked well and made it much easier to remove...
|  5th May 2020 4:36pm |
| Walter Skinner Member Since: 02 Oct 2019 Location: Varna Posts: 61      | Great idea about the carpet, thanks!
|  5th May 2020 4:52pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | Never heard of that scanner but there are some out there which just won't read some ECU's... worth checking yours on another fatty or trying one known to read other fattys ok on yours before you condemn the car...... Pete
|  5th May 2020 5:08pm |
| Walter Skinner Member Since: 02 Oct 2019 Location: Varna Posts: 61      | I'm pretty sure it was reading those modules when I've only purchased the car, I even have some photos of (supposedly?) LCM & PDC ECU's I made when first time hooked the scanner to the car:
|  5th May 2020 6:15pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | Have you checked the fuses...!!
|  5th May 2020 6:27pm |
| Walter Skinner Member Since: 02 Oct 2019 Location: Varna Posts: 61      | Those errors were most probably caused by the dead battery, once cleared they never popped up again... First couple months of ownership everything except Air Suspension & front blower motor was working fine... Than it started to rain & more or less at the same time "LCM" issues started  | ||
|  5th May 2020 6:36pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | Fuses need to be pulled to check them properly, if they have got wet then they can grow salts and can create a high resistance.. Pete
|  5th May 2020 7:15pm |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    | Have you looked inside the PDC module?
|  5th May 2020 7:16pm |
| Walter Skinner Member Since: 02 Oct 2019 Location: Varna Posts: 61      | Yup, with no luck unfortunately. Haven't opened the case, just unplugged the PDC module.
|  8th May 2020 8:50pm |
| Posting Rules
 Once I even got my shoes soaked by the amount of water fell when I've opened Rear Right door after the rain...
