Home > Technical (L322) > L322 2010 4.4 tdv8 gearbox fault
Page 2 of 3 <123>
How long had the car been off..?? 12.6 is a fully charged battery, I bet this is dropping overnight, as you turn on the ignition, the gearbox ECU reads the voltage as low and chucks the fault up.... ?? Pete
Post #552757 5th May 2020 11:41am
Shawser1203
United Kingdom 2010 Range Rover HSE TDV8 Zermatt Silver
I just charged it other day. As I said before, within a couple weeks, it will be down 50% charged. Even after long runs, it doesn't increase the charge.
Post #552759 5th May 2020 11:46am
Probably the battery then, it's certainly the cheapest thing to try first anyway... Thumbs Up Pete
Post #552760 5th May 2020 11:49am
Shawser1203
Exactly, process of elimination. Cheapest thing first.
Post #552761 5th May 2020 11:51am
GGDR
even cheaper is a system discharge / battery reset.
Nothing to loose before you buy a battery.
Then yes a battery would be next cheapest thing to try
. Cheers, Greg
Post #552763 5th May 2020 11:58am
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
I was getting similar readings to that, but as Haylands says it's probably losing some power overnight, and once they get weak and you turn the key its game over as the voltage drops right down.
Post #552766 5th May 2020 12:15pm
Shawser1203
How do you do the system reset and discharge?
Post #552768 5th May 2020 12:24pm
It's in the WIKI, just a battery disconnection procedure, worth a try but don't hold your breath...! Pete
Post #552769 5th May 2020 12:50pm
Shawser1203
I think I've tried that. Taking battery leads off, then touching them together?
Post #552776 5th May 2020 1:13pm
Shawser1203
Just got old battery out. There was a label on the breather pipe on old battery dated 18/11/2010
Post #552788 5th May 2020 3:02pm
Shawser1203
Oh well new battery in, no difference.
Post #552802 5th May 2020 4:06pm
Shawser1203
Also I checked new battery charge percentage it was 70%. After I fitted it, I did the battery replacement on diagnostic tool. After that I put charger back on and it was 50%. Getting a replacement tomorrow to see if its the new battery.
Post #552805 5th May 2020 4:23pm
Shawser1203
Got new battery today. Still the same message. Also noticed not going into low box.
Post #552944 6th May 2020 7:27pm
Shawser1203
Lo box working, didn't do procedure correctly.
Post #552947 6th May 2020 7:32pm
stu1
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Shawser1203 wrote:
No fault codes came up.
Interesting - I would have expected a displayed gearbox fault message to have logged at least one DTC indicating as to why it was showing you the message - what did you read the codes with?
Post #552951 6th May 2020 7:43pm
Page 2 of 3 <123>
