![]() | Home > Technical (L322) > L322 2010 4.4 tdv8 gearbox fault |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
How long had the car been off..?? 12.6 is a fully charged battery, I bet this is dropping overnight, as you turn on the ignition, the gearbox ECU reads the voltage as low and chucks the fault up.... ?? Pete
Probably the battery then, it's certainly the cheapest thing to try first anyway... |
| Shawser1203 Member Since: 29 Jul 2017 Location: Aberdeenshire Posts: 88
Exactly, process of elimination. Cheapest thing first. |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
even cheaper is a system discharge / battery reset.
| diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 491
I was getting similar readings to that, but as Haylands says it's probably losing some power overnight, and once they get weak and you turn the key its game over as the voltage drops right down. |
How do you do the system reset and discharge? |
It's in the WIKI, just a battery disconnection procedure, worth a try but don't hold your breath...! Pete
I think I've tried that. Taking battery leads off, then touching them together? |
Just got old battery out. There was a label on the breather pipe on old battery dated 18/11/2010 |
Oh well new battery in, no difference. |
Also I checked new battery charge percentage it was 70%. After I fitted it, I did the battery replacement on diagnostic tool. After that I put charger back on and it was 50%. Getting a replacement tomorrow to see if its the new battery. |
Got new battery today. Still the same message. Also noticed not going into low box. |
Lo box working, didn't do procedure correctly. |
| stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276
Interesting - I would have expected a displayed gearbox fault message to have logged at least one DTC indicating as to why it was showing you the message - what did you read the codes with? |
| All times are GMT |
