Home > Technical (L322) > L322 4.4 tdv8 2010 transmission module
Shawser1203
United Kingdom 2010 Range Rover HSE TDV8 Zermatt Silver
Where about is the transmission module located. Going to check that, to see if any wires corroded or lose.
Post #552949 6th May 2020 6:35pm
GraemeS
Australia
It is inside the gearbox.
Post #552969 6th May 2020 8:45pm
Shawser1203
So not easy to get to then?
Post #552972 6th May 2020 9:06pm
RRPhil
You miss the point. ZF moved it inside the transmission so that there aren’t any wires to corrode or come loose. It’s part of the Mechatronic unit, which is made up from two modules. One is a ‘standard’ valve block assembly – the hydraulic module - and the other is an electronic module which contains the ECU.
There is a multi-pin connector at the rear of the transmission to allow it to communicate with the car (CAN bus, power, gear position signal, diagnostics, etc.)
Phil
Post #552993 7th May 2020 8:45am
Shawser1203
Cheers Phil.
I just got a diagnostic check and it threw up a code. I'll look it up and post it.
Post #552996 7th May 2020 9:05am
Shawser1203
P279D-02 four wheel drive range signal circuit, general signal failure.
Post #552997 7th May 2020 9:11am
GraemeS
Australia
That suggests a transfer case or ecu problem.
Post #553001 7th May 2020 9:42am
DrRob
Take it to MMP in Dundee maybe for investigation? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #553032 7th May 2020 12:02pm
