![]() | Home > Technical (L322) > L322 4.4 tdv8 2010 transmission module |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2745 ![]() ![]() |
It is inside the gearbox. |
Shawser1203 Member Since: 29 Jul 2017 Location: Aberdeenshire Posts: 88 ![]() ![]() ![]() |
So not easy to get to then? |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1031 ![]() ![]() |
You miss the point. ZF moved it inside the transmission so that there aren’t any wires to corrode or come loose. It’s part of the Mechatronic unit, which is made up from two modules. One is a ‘standard’ valve block assembly – the hydraulic module - and the other is an electronic module which contains the ECU.
Cheers Phil.
P279D-02 four wheel drive range signal circuit, general signal failure. |
That suggests a transfer case or ecu problem. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4345 ![]() ![]() ![]() |
Take it to MMP in Dundee maybe for investigation? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
