![]() | Home > Maintenance & Mods (L405) > Creaking drivers door hinge - what fix? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
That picture is the door check strap Ryan... Make sure the torque bolt is tight holding it (as they come loose ALL THE TIME!!!) |
Thanks Craig 👍🏻 |
brad s1 Member Since: 23 Sep 2008 Location: Boston Posts: 134 ![]() ![]() |
Wd40 isn't a lubricant... put some grease on there. |
Take your point Brad, have ordered female Torx sockets... so I can grease and tighten Torx bolt at same time |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
WD-40 has it's uses, mostly for easing but oil or grease needs to be used afterwards.
Only used WD as a quick indicator to see if it was dry... have different types of grease too |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
I tend to have a can of white lithium grease knocking around which I use for hinges, check straps and the like. Works well, worth giving all the hinges, straps and the like a good squirt with some of that before starting to take anything apart.... |
Their use of the word "lubricant" is loose at best. Technically any liquid could be called a lubricant. It isn't actually a lubricant in the same way something like grease is. Just get yourself a jar of marine grease. |
Boatmechanic Member Since: 11 Dec 2019 Location: West coast Posts: 90 ![]() ![]() |
WD40 contains light oil, and is certainly a lubricant. A lubricant with far better lubricating properties for metal surfaces than water. It is not a relevant comparison.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3799 ![]() ![]() |
There is nothing wrong with WD40 - it has its purposes - so does grease. The secret is knowing when to use them. They are both perfect for their intended purposes.
Correct, it isn't a lubricant in the way grease is... which is what a hinge wants. You wouldn't lubricate your boat prop/shaft with wd40, but it is helpful if you're trying to remove it. They all have their uses. |
Ryan, i wouldn't grease your door check strap as this will give the door less resistance! This will mean the door will keep closing on you!
Slightly loosened the bolt on the door check strap (the one in the middle) by using a female torx socket. When loosened, sprayed some “WD-40 Specialist Range - High Performance PTFE Lubricant”. Then tightened the bolt and hey presto, noise gone 👍🏻 |
johnf Member Since: 16 Nov 2012 Location: Nottinghamshire Posts: 84 ![]() ![]() |
I have the same problem. Don't have any torx sockets though. To save me ordering a whole set can anyone tell me what size I need? Thanks. |
