![]() | Home > Maintenance & Mods (L322) > Aero Front Windshield Wipers Fitted |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Rage against the machine |
That Sonax tyre gel goes on a treat for the scuttle. Use a small kitchen sponge. Much better than an aerosol back to black |
Arkle Member Since: 17 Aug 2014 Location: Cheshire Posts: 173 ![]() ![]() |
Hi Stan, I hope you and yours are all keeping safe. The Conti wipers have been superb. Not a judder or clonk in sight. However, I put the wipers on to wash the screen and the NS one must have been stuck to the glass and has separated. ![]() Can the Conti's still be sourced from somewhere? Fingers and everything else crossed! Thanks in advance. Paul. |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1014 ![]() ![]() ![]() |
Hi Paul, personally - after 4 months of using the HQ's in all sorts of rain and sleet, and hailstones etc - buy the HQ
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
I have never had a vehicle that either required or would have benefited in anyway with any none standard blades.
Hey, Pcourtney, that's great!
The originals clonked and that was annoying and distracting. I'm going to get some of the ones recommended above by Pcourtney. |
credt to Stan Nov 2014 post - I used my daughters protractor and cut it 86 degrees and offered it up to get it exact
When I fitted the Conti's, I just... fitted them without any thought and they've been fine.
They do indeed - when they are worn to the point the rubbers need replacing - my standard ones do not clonk. 2003 Range Rover Vogue TD6 |
Aha... I never though of it that way.
Doonhamer Member Since: 07 Jul 2017 Location: Thatcham, Berkshire Posts: 214 ![]() ![]() ![]() |
Just fitted a set of these - huge improvement in the original fitted ones!. 👍 L322 TDV8 4.4 - current
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 176 ![]() ![]() ![]() |
Could anyone please confirm that I don't need the plastic lock clips if I fit the HQ aero ones, I have broken one of the clips.
bgennette Member Since: 13 Jan 2013 Location: Newcastle Posts: 88 ![]() ![]() ![]() |
Look at all the pictures on this site -
