Home > Maintenance & Mods (L405) > Towing electrics L405
diesel Dave
England 2015 Range Rover Autobiography SDV8 Loire Blue
Hi all. I'm going to order a tow bar (PF Jones) for my 2015 L405 to fit one weekend while i have nowt else to do. I will also order dedicated electrics with this. I believe the electrics need coding to the vehicle, my question is, can the Gap tool do this or do I need more specialist equipment, IE dealer / Indy.
Cheers Dave.
Post #551565 24th Apr 2020 2:08pm
Mine worked plug n play Thumbs Up
Post #551608 24th Apr 2020 10:04pm
diesel Dave
Fab thanks Craig. Will give it a go in the next few weeks Very Happy
Post #551610 24th Apr 2020 10:16pm
Mine were plugged in and supposed to be p and P but they don’t disable the reversing sensors...... so maybe require some fiddling.... There is nothing that can't be fixed with a hammer😜😜
Post #551646 25th Apr 2020 3:11pm
diesel Dave
Well, a little early I know in the current world situation, but the tow bar arrived on Friday from PF Jones. I couldn’t just leave it sat there so I fitted yesterday, all seems to work ok with voltage at fridge and terminal (switched) also a none switched voltage and lights all work on my trailer board so happy days so far. I also did my own cut out on the bumper panel. Not a bad job all in all TBH.
Post #554152 17th May 2020 8:56am
good job..
i think i need to fit a towbar , not that i need one but because i havnt got one.. Confused ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #554156 17th May 2020 9:26am
Dave, have you got a link for that towbar ? ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #554248 17th May 2020 9:19pm
diesel Dave
Hi Stan. Got it from PF Jones. Really good quality piece kit and went on a treat.
Product Quantity Unit price Subtotal
Land Rover Range Rover L405 2013 Onwards Westfalia Detachable Towbar
CODE: 323107
Options: Range Rover 13 Pin Electrics (12-): Vehicle Specific (13PIN496) (+£39.14) 1 £475.94 £475.94
Post #554257 17th May 2020 10:32pm
thanks Dave Thumbs Up ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #554270 18th May 2020 7:19am
Same one I got Thumbs Up
Haven’t had chance to tow with it yet! Did your parking sensors deactivate Dave? As I said mine don’t, everything else works a treat, but the sensors stay on when you select reverse, which is why I suspect it may need plugging in. There is nothing that can't be fixed with a hammer😜😜
Post #554272 18th May 2020 7:50am
diesel Dave
Only had had a trailer board plugged in up to now, but I think I have the same issue as you where they don't deactivate. All other voltage points look ok so will live with it for now. I'm looking at getting an IID tool soon which I think will code it as it does say it has a section for towing electrics.
Post #554298 18th May 2020 10:38am
Mr Tee
Early ones can not deactivate sensors when tow electrics plugged in. Had this conversation with local fitter as the 322 did it automatically. There is no file to change within the car sadly, the later ones can. Step backwards, so you just have to reach across and press the off button, the struggle is real Mr. Green Mr. Green
Post #554310 18th May 2020 12:42pm
