![]() | Home > Maintenance & Mods (L405) > Towing electrics L405 |
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
Mine worked plug n play |
| diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 491
Fab thanks Craig. Will give it a go in the next few weeks |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786
Mine were plugged in and supposed to be p and P but they don’t disable the reversing sensors...... so maybe require some fiddling.... There is nothing that can't be fixed with a hammer😜😜
Well, a little early I know in the current world situation, but the tow bar arrived on Friday from PF Jones. I couldn’t just leave it sat there so I fitted yesterday, all seems to work ok with voltage at fridge and terminal (switched) also a none switched voltage and lights all work on my trailer board so happy days so far. I also did my own cut out on the bumper panel. Not a bad job all in all TBH.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
good job..
Dave, have you got a link for that towbar ? ... - .- -.
Hi Stan. Got it from PF Jones. Really good quality piece kit and went on a treat.
thanks Dave |
Same one I got |
Only had had a trailer board plugged in up to now, but I think I have the same issue as you where they don't deactivate. All other voltage points look ok so will live with it for now. I'm looking at getting an IID tool soon which I think will code it as it does say it has a section for towing electrics. |
| Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2721
Early ones can not deactivate sensors when tow electrics plugged in. Had this conversation with local fitter as the 322 did it automatically. There is no file to change within the car sadly, the later ones can. Step backwards, so you just have to reach across and press the off button, the struggle is real |
