Home > Technical (L322) > Tow bar electrics
steve1
United Kingdom 2006 Range Rover HSE Td6 Bonatti Grey
Tow bar electrics
At the tow ball of my 2002 l322 there's just one wiring plug which obviously utilizes the lights indicators etc, this is Black, there is also a grey plug coming from the caravan which I assume powers the leisure battery, how big a job is it to utilize this grey plug? Hope this makes sense!!
Post #554341 18th May 2020 6:00pm
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
There is a white socket in the right rear corner that the factory kit plugs into, you might find somebody like PF, Jones also have a kit thats plug and play, having fitted several tow bars for different people over the years I had a voltage sensing relay, spare socket and enough wire to make my own up.
Post #554369 18th May 2020 9:05pm
Open the cover on the plug on the car.
Does it have 7 pins or 16 pins?
If it has 7 then you will need a different electric kit to power the fridge, charger etc in the van. If it’s 16 pin then you can get an adapter to plug in both the connectors on the caravan into the one socket.
You can probably get a new tow bar wiring loom for a reasonable price on PF Jones website then just strip out the old wiring and refit the new kit in its place. The sockets should be in place in the right rear cubby fuse panel. There is nothing that can't be fixed with a hammer😜😜
Post #554397 18th May 2020 10:33pm
Gazcw
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
If it is 16pin I have a convertor which is of no use to me any longer. 2011 4.4tdv8 Vogue
Baltic Blue
Post #554405 18th May 2020 11:21pm
Dizzy Dee
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Of you mean the socket on the rear of the car, then it will be 7 or 13 pins. Like below.
Post #554414 19th May 2020 7:23am
Sorry, late night brain fade.... Whistle There is nothing that can't be fixed with a hammer😜😜
Post #554418 19th May 2020 7:37am
steve1
It's the 12n as above with no other plugs in the vicinity
Post #554445 19th May 2020 11:38am
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Here you go Steve, that would replace the lot, or you could just search for the single 12 N with ECU box, but that seems a good price to me, and you'll get all the instructions to fit it too. Thumbs Up
Range Rover 03/2002-08/2009 Twin 12N/12S Dedicated Wiring Kit
CODE:37190503PF
Brand: PF Jones
Socket Type: Twin 12N & 12S
PF Jones Code: TPIN002
Vehicle Coding: Not Required
Trailer LED: No
Quantity:+−
Questions
Shipping Cost
Electrics Explained
Fitting Instructions
£132.45 Price includes VAT
Post #554446 19th May 2020 11:48am
steve1
Cheers Dave I'll get on with that many thanks
Post #554450 19th May 2020 12:15pm
Dizzy Dee
I do have a 15 pin on my trailer and truck, stops other folk towing it. Twisted Evil Like this.
Post #554507 19th May 2020 8:57pm
