Home > Maintenance & Mods (L322) > Fitting bull bar and rear lamp guards to a 2011 RR Vogue
jackie-o
Netherlands
Hi,
I want to fit the LR wrap around bull bar and rear lamp guards to my 2011 car.
However, these are only available for vehicles up to 2009.
Does anyone know if these parts can be modified to fit a 2011 car with the latest front bumper and rear lights?
cheers
J RR Vogue 4.4 TDV8 - 11
Toyota Land Cruiser Prado - 02
LR Discovery 4 SDV6 -11 - Gone
RR Vogue 3.6 TDV8 - Gone
Post #554552 20th May 2020 8:00am
mjdronfield
The rear lights are interchangeable with the older units physically, so I can’t see why those lamp guards wouldn’t fit.
The bull bar may be a different story. Someone with more knowledge of the differences due to the facelift should be along soon......
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #554555 20th May 2020 8:38am
Just one point I can think of, if you have adaptive cruise the bull bar will probably stop it working...maybe..!! Pete
-Click here for Thread-
Post #554558 20th May 2020 9:29am
verydisco
There was no bull bar or soft rubber bars for the 2000-on L3222s - these became ban by European standards a couple of years before that.
You'll have to modify you bar or bumper to install and fit it.
The rear light grills are fitted to the brackets holding the rear2002-2009 lights. However, from 2009-on the light clusters have a different clip-on system and can no longer receive the 2002-2009 rear guard.
Unlike the 2002-09 lights cluster, the newer ones do not have the cutouts to let the guards' metal bracket fit between the cluster and the bodywork.
You would have to modify the lights cluster' plastic edge and create brackets. So it is not impossible but a serious job. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #554562 20th May 2020 9:50am
jackie-o
Netherlands
Thanks for the replies, specially verydisco!
I´m guessing the shape of the front bumper may have changed slightly after the 2010 facelift so the bullbar may not fit tight either. Even if the mounting is sorted?
Will probably shelf this little project Sad RR Vogue 4.4 TDV8 - 11
Post #554566 20th May 2020 10:32am
I modified a soft bullbat to fit the top of a 2009> front bumper as i was intending to build a dedicated off-roader... I will take a pic when i get a moment Thumbs Up
The rear light guards would cover the indicators on a 2009> Lamp if my memory serves me right???
Post #554589 20th May 2020 12:51pm
jackie-o
Netherlands
@Craig please do!
If it is not too much work then maybe I will have a go at it.
Regarding the lamp guards, does this mean it will risk failing an MOT? RR Vogue 4.4 TDV8 - 11
Post #554680 20th May 2020 9:14pm
