Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A *** |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3192 |
Other than that I'd go with Joe90 and consider the compressor. John
22nd May 2020 6:55pm |
A 30 second search on the Gap website reveals - NO for Td5.
23rd May 2020 9:35am |
MattHughes86 Member Since: 01 Jun 2019 Location: Gloucestershire Posts: 140 |
Cheers for that.
26th May 2020 12:26pm |
John
26th May 2020 12:59pm |
Johnniehec Member Since: 03 Feb 2017 Location: A a Posts: 22 |
Well, suspension problem is solved, replacement compressor, all now working. Still strange there was no fault coming up and less than 10k miles since pump refurb kit fitted.
9th Jun 2020 12:02am |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
I have noticed something strange with my IID Diagnostics since I upgraded from my old TD6 to a 4.4 TDV8. I have the 8-Speed gearbox, however whenever I plug the diagnostics in and go through the ECUs, it says I have a 6 Speed gearbox. I've had the licence changed over by Gap to the new 4.4 TDV8 and checked I've got the latest software running, so does anybody else have the same on their diagnostics tools, or is it something I need to get in touch with the Gap guys about? |
9th Jun 2020 1:09pm |
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 |
Have you looked at the CCF file to see if it is set to 6 Speed? Just a thought 2011 TDV8 Vogue SE |
9th Jun 2020 1:12pm |
@dennij, hmmm...might pop out and have a look in a short while. Can't see though how you would be able to config a 8 Speed Ecu to read as a 6 Speed Ecu. |
9th Jun 2020 1:26pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34907 |
i remember something like this mentioned before...i think its a bug in the software.. ... - .- -.
9th Jun 2020 1:30pm |
Stan, is that a bug in the Gearbox Ecu software or the IID Tool?
9th Jun 2020 1:40pm |
bug in the iidtool..give pat at GAP an email to confirm.
9th Jun 2020 1:44pm |
Not much info in the link, GGDR had said he would email Gap about the gearbox readings, but nothing further in his thread, so I've sent a query to the guys at Gap Diagnostics.
9th Jun 2020 2:13pm |
Full Fattie Member Since: 10 Aug 2018 Location: Sunderland Posts: 245 |
Hi
22nd Jul 2020 12:25pm |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 364 |
It's normally as your sitting in the car, so front right is off-side front in the UK.
11th Sep 2020 5:10pm |
