![]() | Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A *** |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Quick one....does the IID allow you to see distance or time since last service interval reset?
| Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3284
Yes it does. It lets you see time and distance I remember . |
Do you know where? Live Values I’m thinking 🤔 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
| Ian928 Member Since: 16 Aug 2016 Location: Kristiansund Posts: 84
I have a 2006 SC with 4 new Oxygen sensors. I now have a P0160-00(E |
| rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198
[quote="flashgordon"]Currently I start my trip with connecting the GAP Tool and
I haven't gone through the manual reading as per the IID non BT, but it does say that the manual only differentiates between the non BT, BT and Pro where there are differences. So i would think if you look at what you want to achieve with yours you should be able to get a result, if that reading is available on your model year. Cheers Richard (there are no such things as an ordinary FullFat, an ordinary cat or too many tools) 2011 TDV8 Vogue Santorini Black Gap IIDBT |
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2297
Two questions-
I have looked through the live values section in the menu without finding it, it is probably not available for my car then. Thank you! 2006 Supercharged |
Ian
| flashgordon Member Since: 23 Sep 2019 Location: Hannover Posts: 76
[quote="rjff"]
Thanks a lot. YES Super! |
| Leesbay Member Since: 05 Dec 2019 Location: Rainford Posts: 53
Hi I have had an cruise control not available along with forward alert not available message and have used the IID to do a radar recalibration
| Johnniehec Member Since: 03 Feb 2017 Location: A a Posts: 28
Hi can someone from GAP help with this one please?
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3276
@johnniehec
No maybe that’s my downfall though the symptoms were already there before I jacked it up, put it on axle stands and disconnected the airlines from the reservoir and valve unit, there was only about 20 psi in the tank at the time. I’ll have a look at that reset procedure thank you |
