|  | Home > Maintenance & Mods (L322) > DPF full 4.4 TDV8 2012 |
| SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 263      | What can cause the soot level to rise so quickly?
|  23rd May 2020 4:33pm |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561      | You may have another leak.  Could be any joint or union.  The four hoses are typical.
|  23rd May 2020 5:29pm |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3285      | Poss an air leak, either in a pipe or poss cracked inlet manifold. mine had a minute crack which made the DPF fill up quickly. | ||
|  23rd May 2020 5:51pm |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352      | Have you had a smoke test done on it? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
|  23rd May 2020 7:07pm |
| SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 263      | Dr Rob, I would not have a clue where to get one done.
|  23rd May 2020 11:04pm |
| SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 263      | GGDR
|  24th May 2020 9:21am |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3888      | Greg will be along with a better reply, I am sure, but until then, have you carefully wiped all around it with a white tissue ??
|  24th May 2020 9:36am |
| SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 263      | Would really appreciate if any one has a schematic of this joint it does seem very loose, and yes, it has oil residue around it.
|  24th May 2020 9:49am |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3888      | Sorry Steve but I can’t find any detail pictures of the joint but from Greg’s experience, you can be fairly confident that you have found your problem.
|  24th May 2020 10:02am |
| SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 263      | Hi Baltic
|  24th May 2020 10:26am |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3888      | I have just had a bit of a prod and pull on mine plus a wipe round.
|  24th May 2020 10:35am |
| SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 263      | Thanks Baltic
|  24th May 2020 11:19am |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561      | Hi guys,
|  24th May 2020 12:46pm |
| SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 263      | Cheers Greg
|  24th May 2020 1:35pm |
| Posting Rules
