|  | Home > Maintenance & Mods (L322) > DPF full 4.4 TDV8 2012 |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352      | Get a white tissue and run it under the joint too. It might be hidden   | ||
|  24th May 2020 1:47pm |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352      | https://www.fullfatrr.com/forum/post550968.html#550968 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
|  24th May 2020 1:48pm |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3888      | Gents,
|  24th May 2020 2:04pm |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561      | Nothing wrong with that Mike, same as PTFE.
|  24th May 2020 2:18pm |
| SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 263      | Cheers guys
|  24th May 2020 2:23pm |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3285      | GGDR Quote: "I did a low pressure smoke test which revealed nothing.
|  24th May 2020 2:28pm |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561      | Dolphin -   | ||
|  24th May 2020 2:50pm |
| dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450      | Inside the plastic pipe connecting to the throttle body is a seal. I gently removed mine and cleaned it carefully before putting it back. it has a clearly defined lip that is supposed to create an air tight seal, although I'm not convinced it's up to job after a number of years under the bonnet with the temperature extremes it has to cope with. My pipe also has a lot of movement, at least more than I would expect, even with a good fitting clip. Ideally a new seal would be available but my understanding is that you cannot buy these separately. As already mentioned I would clean the whole area and look for any oil residue that is showing. Ideally you'll need to ask around a few garages to see who could carry out the high pressure smoke test as this will confirm if you have a leak and where it is. 2011 TDV8 Vogue SE | ||
|  26th May 2020 8:30am |
| SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 263      | dennij
|  26th May 2020 9:24pm |
| dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450      | Hi Steve, I haven't been able to use it much since the lockdown. I took it for a 70 mile run 2 weeks ago and had no issues apart from the plume of smoke when I put my foot down but this would be the 2nd turbo oil issue (well documented). I am out in it again on another 70 mile round trip today (work purposes) so will report back later as to how it went. I would recommend cleaning the seal inside the plastic pipe that connects to the throttle body, just take a note of how it sits in the recess before you remove it as it has a prominent lip that appears to me to only be effective if fitted correctly. I still find the amount of free play in this to be more than I would like but it seems that this is the way it's been designed to fit. Prior to removing and cleaning I did have a slight misting of oil in this area so that may have a bearing on the issue I'm having currently. Problem for me is that whenever I venture out I'm always concerned about if the plume of smoke is going to suddenly appear again so it spoils what should should be an enjoyable driving experience. I did read an article about the 2nd turbo expelling excess oil automatically if the level reaches a certain level, meaning that the oil would be burnt off as it entered the exhaust system, however, I am unable to find the article again so not sure whether it's accurate or not. Leaves me wondering if it's worth going for the turbo drain modification, although if that doesn't improve things it's a lot of money wasted. 2011 TDV8 Vogue SE | ||
|  27th May 2020 7:16am |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352      | Dennij - keep us posted! It's advisable to boot the motor (when warm) to prevent the oil pooling in the 2nd turbo. They appreciate their taps being opened up regularly   | ||
|  27th May 2020 7:24am |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3888      | dennij,
|  27th May 2020 7:32am |
| dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450      | Hi Mike, as you say, the plume of smoke is embarrassing, last time I had to open the taps was to pass a couple of cyclists who became engulfed in the cloud I was leaving behind, hardly a good advert for us folks that drive around in these cars. It does clear if I have to boot it again but I'm at that stage where I'm happy to just waft around rather than chase the 0 - 60 MPH times. Interesting to read your comments after having had the turbo drain mod carried out, it's one of the reasons I've added it to my to do list if other remedies fail to resolve my issue. Just need to get my indy to open and clear his backlog of jobs so I can book in for a high pressure smoke leak test, assuming he can do it of course. 2011 TDV8 Vogue SE | ||
|  27th May 2020 7:52am |
| SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 263      | Hi dennij
|  27th May 2020 8:13am |
| Posting Rules
