![]() | Home > Maintenance & Mods (L322) > DPF full 4.4 TDV8 2012 |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3239 ![]() ![]() ![]() |
You don’t necessarily need to boot it to get a RP message. If you look at some of us who have suffered similar, the RP came up when under gentle acceleration or Holding a steady rpm. Mine always occurred on the same stretch of my commute (M4) at 75 mph, just as a small demand was made on the engine at the start of a slight incline. I could almost guarantee when it would happen.
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
Had a quick look under the bonnet, the plastic pipe to throttle body is nice and dry but on the plenum there is clearly some oil misting to see. Would be nice to think that this is down to the oil filter cover and not the plenum itself although not hopeful. As soon as I can get the high pressure smoke test carried out I will provide further updates
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 ![]() ![]() ![]() |
Well at least I have some good news.
Hi Steve, that all sounds very positive, hopefully it was just those plenum pipes that were giving you the issue. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3850 ![]() ![]() ![]() |
Good news Steve |
Hi BB
Mate!!
Quick update
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3553 ![]() ![]() ![]() |
Ok let’s see how you get on there Steve.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
How did it pan out Steve? PTFE done the trick? Hope so |
Hi Dr Rob
