![]() | Home > In Car Electronics (L322) > l322 2003 voice & phone |
| tommo10ferrets Member Since: 29 Apr 2020 Location: leicestershire Posts: 56
Morning all, quick update, the antenna arrived the other day, connected it all up, linked 32 & 36, nothing, head unit is still saying "Activate Phone" quick question, when the ulf is plugged in to wiring loom, are any lights supposed to be on ? on the head unit where there are 3 lights for telephone, if so, I have none ! any help would be appreciated.
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7994
You need to read my pairing link on the previous page.
Hello MJ, thanks for your response, what I have done just to see if it works was to take off the plug shroud, plug the blue pin connectors into the ulf module so that the unit is connected, from there I bridged out the pins between 32 & 36, nothing, activate phone still showing on head unit, have also tried stripping plastic sheath off both 32 & 36 wires & bridged across them, plugged unit in again, still nothing, that's why I asked the question this morning as to any lights on the head unit lighting up to indicate if unit is working, I noticed in someone else's post that he had a red light showing, although the person that answered didn't think the red light should have been on. it could, I presume, be a duff ulf module, but how can you tell without buying another unit considering the lack of indication on the 3 telephone lights on the head unit ? Would the actual ulf module require "turning on" / " activating" as such, via Navcoder or similar programme? I have just sent off for a Navcoder cable with usb & OBD port connection, also downloaded the programme, although the seller couldn't guarantee that it will work with the Range Rover
I had Navcoder, it does work on the RR, but I didn’t use it for this.
Hello, yes but still no joy, that's what makes me think the ulf maybe duff, but as I said there is no way I can see that the unit can be checked, although the unit does show up on my icarsoft analyser & on the head unit, along with BMW Assist!!! so I don't really know which way to go now.
Hi, you have to follow the pairing procedure, I will try and find it....it’s something like bridge wires....ignition on...within 5 seconds pull wires apart.... the 3 lights then flash on the head unit and it’s looking for a phone.....
https://www.fullfatrr.com/gallery/albums/u...Manual.pdf
Hello tried that this morning, not sure if I got round to the ignition within the 5 secs though, the wife has just got back from shopping so I'll get her to switch on ign while I disconnect bridge within the time frame, can only try, but if you do find the procedure please do put it on the post, be very much appreciated, just going outside to try, will let you know what happens....if anything that is. Thank you
That shows everything as it’s the ULF Owners Manual.
Think you might have been replying to me as I posted the manual.
Hello MJ, Success to a degree, followed the pairing process you posted for me, thank you, it paired, now its saying it cannot connect, think I will try the pairing process again in a little while (when it gets a bit cooler outside), although there are some phone numbers coming up on the head unit screen, but I don't recognise them, when a phone number appears on the dash display & I scroll forward, it say phone book empty. At least we know its working to a degree, hopefully a little bit of fine tuning is all that's required, once again thanks for your help, will keep you posted.
You are welcome mate.
Hello MJ, re-paired the phone, that's ok now, but still getting the old stored numbers coming up, manually inputted wife's number & it rang out ok, but she couldn't hear me, I could hear her plain as day, so I will look in centre console to see if mic is connected there, I know its connected in the overhead light binicle as I bought a microphone & fitted it(the right way round) My phone is a Samsung A8 2018 model. But tomorrow is another day, as least some progress made today, which I'm please about, thanks for all your help.
| Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1100
Tommo
