Home > Wheels & Tyres > Replacement Locking Wheel Nut
sgreenham
2015 Range Rover Vogue SE SDV8 Corris Grey
One of my locking wheel nuts has had a layer of paint taken off and has surface rust on it. Does anybody know if it is possible to replace an individual locking wheel nut? I'm assuming there is only a certain amount of Land Rover locking wheel nut patterns so maybe a replacement is possible without having to change all of them
Post #555933 30th May 2020 6:26pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
It should tell you what type it is on the socket you use to remove it. I think that the early ones are marked A, B, C, D & E
Jim
Post #555935 30th May 2020 6:52pm
jim4244
To be honest most folk on the forum, myself included, remove the locking wheel nuts due to the chan e of them failing and then having to be cut off.
Nothing like getting a flat in the dead of night, on a rain swept road across the moors and then have your locking wheel nut fail......
Jim
Post #555936 30th May 2020 6:55pm
recordman
United Kingdom 2017 Range Rover Autobiography SDV8 Aruba
I've just got rid of my locking wheel nuts and replaced them with normal ones. 2017 SDV8 Autobiography
Post #555941 30th May 2020 8:01pm
p38arover
Australia
Yep, I got rid of the locking nuts, too. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #555966 31st May 2020 2:55am
DrRob
Ditch all locking nuts
Check all other ones have not swollen. If the socket is tight to go on then replace that nut.
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #555968 31st May 2020 6:22am
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Yup, had to get a specialist to remove mine , they are awful , took them off. Thumbs Up
Post #555970 31st May 2020 7:18am
sgreenham
Thanks for all the replies guys. Why are they so bad on a Range Rover? Never had any issue before with locking wheel nuts?
Post #556025 31st May 2020 4:04pm
jim4244
The locking nut is a 2 part design. Sometimes, particularly on older car with original locking wheel nuts, the top part with the notches detaches from the bottom solid part. This results in the top part just spinning and you then have to cut the locking wheel nut off.
Jim
Post #556045 31st May 2020 6:37pm
DrRob
Same on Disco 3 and 4 and Sports. Same Censored design of nut Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #556051 31st May 2020 7:11pm
CS
The tyre shop I use warned that if the locking nuts are overtightened they can be a real problem to get off, easily done with air tools etc. They recommend only hand tools be used, saying that the air tools are also a contributor to the nuts swelling, on the basis that they blow damp air under the nuts. Anyway, I've removed the locking nuts on the last two RRs and just have standard ones. I'm not one for jet washing or chemical cleaners when the wheels are on the car either. Only Range Rovers since 1988
Post #556064 31st May 2020 8:19pm
DrRob
Replace your nuts every year Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #556070 31st May 2020 8:55pm
GGDR
Is there a metallurgic reason LR don't use solid stainless?
Stainless more brittle?
Or reactive between the steel stud and the alloy wheel?
Something to do with loading rate?
What do other (heavy) cars use?
. Cheers, Greg
Post #556072 31st May 2020 9:07pm
It's impact guns that knacker the nuts - they rattle them loose.
Mine have been fine since I insisted on hand tools only.
Post #556092 1st Jun 2020 5:45am
CS
When I asked the dealer foreman about solid stainless nuts he advised against, saying stainless would be worse for galvanic corrosion. That seemed counter-intuitive to me so I searched online, and there was some evidence from the US construction industry to support it.
Stainless nuts are good though for Defenders with steel wheels, where galvanic corrosion is not an issue. Only Range Rovers since 1988
Post #556107 1st Jun 2020 10:37am
